Old November 14th, 2019, 10:00   #1
Mikey-s
Default BV43A chra into BV43
Hi, I have a BV43 170hp BRD turbo to go on my A4 AFN. I'm going to replace the chra but I was reading the BV43A chra is a direct replacement and will help with faster spool up. I can get the below chra from Melett in the UK, can anyone confirm this is the one that will fit my BV43? https://www.turborebuild.co.uk/websh...io-20-TDI.html
Mikey-s is offline   Reply With Quote
Old November 14th, 2019, 23:06   #2
adamss24
Fuel Economy: 35-45mpg
Just buy a genuine used bv43a turbo, they are cheap... Yellow tag is what you want... That one you've linked in the post looks like it has a cast compressor wheel, the genuine bv43a has a 6+ 6 blade billet alloy compressor wheel...you want the whole turbo as the actuator swaps with the housings- saves messing about with adjusting actuators...
adamss24 is offline   Reply With Quote
Old November 14th, 2019, 23:12   #3
Mikey-s
It was one of your posts that got me thinking of the BV43A chra. The BV43A has a different compressor outlet, or at least I think it does, plus I already have the BV43. I think that photo is just generic, I'm more after the part number confirmation. Thanks for your help.
Old November 14th, 2019, 23:14   #4
adamss24
Out of curiosity, what car do you have ? Any mods on it ?
Old November 14th, 2019, 23:15   #5
Mikey-s
A4 afn
Old November 15th, 2019, 21:45   #6
adamss24
Yep, just as i mentioned in that post, you take the PD turbo and swap in the whole cartridge from CR turbo into the pd housings...didnt i make that clear enough ? I would be very surprised i the Mellet Chra does have billet compressor on it, they build replacements so not necessarily buy replacement parts from Borg Warner/KKK ! From actual experience, mellet pictures on ebay are actual pics for the items they sell so returns are minimal !
Old November 18th, 2019, 20:34   #7
Mikey-s
Found this pic from another Melett dealer which shows a billet impeller.
Old November 18th, 2019, 22:22   #8
adamss24
Then it looks like the right part ! I was stressing on using genuine due to the fact that you dont need to adjust the actuator with another turbo as its bolted to the chra vnt arm...
Old November 18th, 2019, 22:51   #9
Mikey-s
Turborebuild.co.uk who are a Melett dealer are fairly close to home, I'll give them a call later to confirm this has the billet wheel.
Old November 19th, 2019, 05:28   #10
Mikey-s
So it's confirmed the Melett BV43A chra does have the billet wheel, see the quote from Turborebuild.co.uk. I'll get my turbo over to them to see if they can fit one and setup the stop screw and actuator.
Old November 20th, 2019, 00:03   #11
adamss24
The genuine kkk bv43a chra fits into bv43 housings without fouling on the housings- i have used quite a few along the years...
Old November 20th, 2019, 00:04   #12
Mikey-s
Ok perfect, thanks for the confirmation.
BV43A install in my 2005 B5.5 BHW 50harleyrider VW B5 Passat TDIs 100 July 15th, 2019 15:07
bv43-109 vs bv43-189 Kody TDI Power Enhancements 4 September 28th, 2017 13:41
turbo swap to BV43a db747 TDI Power Enhancements 5 March 5th, 2015 19:36
WTB BV43A turbo Spring1898 Private TDI Items for Sale/Wanted 8 November 27th, 2014 13:49
BV43A VNT Actuator Adjustments CarlosVW VW B5 Passat TDIs 5 August 23rd, 2014 19:10
Page generated in 0.15701 seconds with 13 queries
[Output: 102.52 Kb. compressed to 86.40 Kb. by saving 16.12 Kb. (15.72%)]
