Old November 12th, 2019, 18:41   #1
Jazz_3b
Default 05 2.0 bhw tdi make it run
I'm working on swapping 05 passat 2.0 tdi bhw to 01 chevy s10 with a Toyota dually rear end i got the engine in there but can get it to fire i did the immo delete i thank the ecu is disabling the injectors I do not have the cluster plugged in is it still required even though I did immo delete
Jazz_3b is offline   Reply With Quote
Old November 13th, 2019, 12:16   #2
PickleRick
PickleRick's Avatar
Stupid question...have you bled the fuel system? Takes a while to prime the.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old November 13th, 2019, 15:57   #3
Jazz_3b
Sure did I also have a continuous pump right now just till I get it running then it will be relayed I let the fuel go to the end of the line before hooking it up left it running for a little while to let it circulate make sure there was no air in the filter before I started cranking I can put a little starter fluid in it and it will fire and run for couple second
Old November 13th, 2019, 16:02   #4
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Have you scanned it for fault codes? If the immo is triggered there will be a fault for it. It reads something like "Engine start blocked by immobilizer".
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old November 13th, 2019, 16:03   #5
Jazz_3b
It might also be in my wiring harness on the cabin side not sure 100% what wires I needed to be hooked up I played around on Google for days trying to find a wiring diagram but it seems that the Germans are a little stingy with them lol
Old November 13th, 2019, 16:09   #6
Jazz_3b
Immo deleted no codes for it but the codes that i am getting are p0727, p0600, p0102, p0546, p0230 I did remove the oil pressure sensor and put a Chevy one in its place
Old November 13th, 2019, 20:31   #7
PickleRick
PickleRick's Avatar
Did you not use a wiring schematic for the passat? If no do you need one? If the answer is no you do need one.
Old November 13th, 2019, 20:44   #8
Jazz_3b
Yes I need wiring schematic I just disconnected all the things I figured I didn't need
Old November 14th, 2019, 04:51   #9
PickleRick
PickleRick's Avatar
Please pm me your email address
Old November 14th, 2019, 06:41   #10
Jazz_3b
Also can anybody direct me to a tuner/programmer to delete/disable the sensors I don't require so the engine will stop throwing codes and what sensors do i have to have plugged in to make this diesel run still learning the tdi's definite newbie
Old November 14th, 2019, 08:09   #11
PickleRick
PickleRick's Avatar
Whitbread perfomance did my imob delete and stage 2 tune. Matt owns and has done BHW swaps. Can help you out. Great guy.
Old November 15th, 2019, 18:05   #12
Jazz_3b
Did you do your own wiring harness or did he make you a custom one
getting fuel now but still not firing got to be in the wiring harness something I don't have hooked up or something I removed
Old November 16th, 2019, 04:02   #13
PickleRick
PickleRick's Avatar
Im not sure if matt will do wiring or not. There are members here that do both the tuning and if you send them your harness will reduce it down to only the ones you need.
Old November 18th, 2019, 12:02   #14
Jazz_3b
Can you do it and how much? Do you need both or just interior white bread guy been trying to get ahold of him for the last 3 months no answer call or email
Old November 18th, 2019, 19:07   #15
PickleRick
PickleRick's Avatar
There are a few other vendors on this site, maybe someone can chime in on who to suggest.. In order for me to do it id need the entire s10 plus uncut s10 and passat donor harness to combine them, with my schedule and personal projects going in I'd also need a good 9 months to do the work. I hate daylight savings and cold weather. Being that you've already cut your harness that may be an issue.
I believe the last quote i got for a plug and play BHW harness was @500 and another 400ish for tune.
Blown Turbo? 05 BHW TDI Passat Dr. Greenthumb VW B5 Passat TDIs 44 June 20th, 2019 15:06
WTB 04-05 TDI BHW engine Patriarch Private TDI Items for Sale/Wanted 0 August 26th, 2013 08:08
WTB 04-05 TDI BHW engine Patriarch TDI Cars for Sale/Wanted 0 August 26th, 2013 07:59
BHW Oil Filter Location '05 Passat TDI passat77445 VW B5 Passat TDIs 9 March 8th, 2009 14:09
What is needed to make TDI run crossle32 TDI Conversions 16 April 18th, 2008 14:13
Page generated in 0.17840 seconds with 13 queries
[Output: 123.88 Kb. compressed to 101.99 Kb. by saving 21.89 Kb. (17.67%)]
