Old November 17th, 2019, 11:50   #1
gearheadgrrrl
Fuel Economy: Other than the JSW, hard as I try, can't seem tio get below 40 MPH!
Default Good bearing puller for rear wheel bearings?
Gotta get the original bearing off to replace the rusted out brake dust shield on an '03 Golf, did the other side with chisels a few months ago but would like to be a bit gentler. Any suggests for an affordable puller?
GearHeadGrrrl
gearheadgrrrl is offline   Reply With Quote
Old November 17th, 2019, 11:53   #2
fire32njetta
Harbor freight? Or maybe rent from autozone or something like that
2003 Alaska Green Jetta TDI
*2.5" Turbo-back straight pipe, PP520's, RC3 , VR6/G60, DG Sigma5 SS*
fire32njetta is offline   Reply With Quote
Old November 17th, 2019, 19:14   #3
csstevej
Any gear puller to pull 90% of the bearing off.
The inner race of the inside half will still be on the stub.
Get a Dremel or cutoff wheel an score the inner race pretty good without going too far, use a sharp chisel and give it a couple of whacks and it splits the inner race.
Then just pull it off.
Put the new rear bearing assy on torque nut and your set.
Takes maybe an hour a side if you work slow .
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old November 18th, 2019, 10:15   #4
vandermic07
Fuel Economy: 47-51 MPG
I second CSSTEVEJ.
Ive done 4 wbs like this. The 1st time i messed around trying to pull it with pullers. ended up destroying them by grinding them thin. I also wasted a ton of time.
1 hr is very conservative for them dremel method.
vandermic07 is offline   Reply With Quote
Old November 19th, 2019, 19:23   #5
tgray
I always warm only the inner race up with a propane torch so it is just hot to touch. Do not burn the grease or put flame on the bearing or make the metal turn blue or you have ruined the bearing. Slide the hub and bearing race on. If it stops before the bottom the nut will pull it down. Hammering bearings on is not a good thing as it can damage them. I use a cut off air tool instead of a dremel to cut the old race and then chisel.
tgray is offline   Reply With Quote
Looking for wheel bearing puller Wingnut Ontario 7 October 31st, 2013 18:54
wheel bearing puller whasup TDI 101 1 June 5th, 2010 15:28
Front Wheel Bearing Puller RyansToy Atlantic Canada 13 September 22nd, 2009 17:48
wheel bearing puller bryantdi2 Ontario 1 November 28th, 2005 20:13
Front Wheel Bearing Puller Kubbie69 VW MKIV-A4 TDIs (VE and PD) 12 March 13th, 2003 18:53
Page generated in 0.15751 seconds with 13 queries
[Output: 67.91 Kb. compressed to 60.13 Kb. by saving 7.78 Kb. (11.46%)]
