Old November 6th, 2019, 08:29   #1
vwdsmguy
Fuel Economy: 49/46/42
Default leaking master cylinder
My fluid diapppears till I get a soft pedal a few months later after being full. Has anyone found it leaked into the booster in the back end of the cylinder? I could just add fluid every few months, 1/2 cup or so, but I need a real fix. I can't find evidence of any obvious leaks elsewhere. Also, sometimes when cold I get a trail of bluish smoke on my first long down hill. It looks like a PITA to change the master, so I have been putting it off. Also, is there a test positive for this leak issue?
'02 Golf TDI, RC5, PP764's, FMIC, 2.5" T-Back, OMI, SB-3 clutch, 11mm pump, VNT17/22, 3 Bar MAP, CAT filter, 90 GPH Holley lift pump, modded D24 intake manifold, Rosten rods, Nural pistons, ported head - 15.0 @ 94 at the drags
vwdsmguy is offline   Reply With Quote
Old November 15th, 2019, 08:58   #2
vwdsmguy
Default leaking brake fluid
I might not have a brake issue. It could be in the clutch hydraulics because I have something leaking on the drivers side of the under engine pan, however the clutch pedal action feels normal. Both clutch and brake masters feed from the same reservior. i can't believe the cost of the clutch hydraulic line [$133], so I hope it's not that.
Old November 15th, 2019, 22:20   #3
KLXD
It can leak into the booster.
Brake fluid is water soluble, is the fluid you see leaking? Time to remove the pan and do some looking. Could have a small leak that doesn't affect funcfuncfunction.
Saying no to gas for 25 years:
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
KLXD is offline   Reply With Quote
Leaking Clutch master cylinder??? Asbury030 VW MKIV-A4 TDIs (VE and PD) 3 November 8th, 2018 06:52
2006 Not Starting and Leaking Brake Master Cylinder upchurch17 VW MKV-A5 Golf/Jettas 4 February 3rd, 2016 16:07
Brake master cylinder/clutch master cylinder? dweisel VW MKIII-A3/B4 TDIs 16 July 2nd, 2015 20:09
Clutch master cylinder or Slave cylinder, Which is FAIL ? Mcgink VW MKIII-A3/B4 TDIs 22 November 26th, 2014 14:34
Urgent clutch master cylinder leaking srmichi TDI 101 9 June 21st, 2011 15:56
Page generated in 0.14997 seconds with 13 queries
[Output: 58.75 Kb. compressed to 53.22 Kb. by saving 5.53 Kb. (9.41%)]
