Old September 25th, 2019, 09:05   #1
50harleyrider
Default how to loosen those 3 T-55 torque converter bolts
Cheeter bars, one broken t-55 socket, beat on it with a long brass bar, even tried my air impact, and still no luck. Those bulders must have used a really potent thread locker. I guess I have to try heat next and hope I don't start a fire. Help!!
50harleyrider is offline   Reply With Quote
Old September 25th, 2019, 10:44   #2
oilhammer's Avatar
Fuel Economy: fantastic
Snap-On Torx bit, 3/8" drive, flywheel locked through the hole in the bottom, never had an issue. They are tight, yes, but I have probably had 1000 of those bolts out with the exact same tools.
I do not think heat will do much, since the fluid filled torque converter they screw into will likely pull the heat away just as fast as you can put it in.
I'd just try a better name brand professional grade tool, make sure you hold it square to the bolt so it doesn't walk out on you.
www.cardocautomotive.com
Old September 25th, 2019, 12:09   #3
DeliveryValve
There shouldn't be any thread locker on those bolts. The specified torque is 63 ft lbs.
The main thing is keeping the tool straight. I position the flywheel so I can "lean" the socket extension on the engine block. This would help in keeping it straight and giving you more leverage.
- Richard-
2005 Passat TDI GLS Wagon 21x,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old September 25th, 2019, 15:31   #4
thundershorts
Quality tools always seem to work better whatever you're doing, they fit better as well.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old September 26th, 2019, 05:28   #5
50harleyrider
thanks guys. Oilhammer, you're an eternal light in our darkness. Is that lock pin a zf specific one like the engine lock pins or any old screwdriver will do?
Old September 26th, 2019, 05:44   #6
oilhammer's Avatar
I use a chunky screwdriver (also a Snap-On ) to hold the flywheel from turning through that lower sort of Saturn-shaped hole in the bottom of the bellhousing.
There is also a tool to go up through there to help push the converter out of the end of the crank (after it is unbolted from the flywheel) but I have never needed to use it. I just gently push the converter out with the last loosened bolt, gently rocking it back and forth. Then I reach in the starter hole and continue to be sure it is pushed away from the engine when I go to move the transmission back off the block. If you do not do this, and the converter comes out of the transmission instead, you will have a heck of a time getting it back IN while the trans is up in the tunnel, and there is not enough room to leave the converter on the flywheel and remove the trans without really angling the engine WAY down (which requires disconnecting some other stuff).
Old September 26th, 2019, 18:09   #7
50harleyrider
Worked. Those VW installers in Germany really like a potent dose of thread locker. Every bell housing bolt as well as the tc bolts required a 3 ft cheater bar with all the strength I could muster to break loose.
Old September 27th, 2019, 11:27   #8
zzdiesel
Perhaps it has been removed since new. No threadlocker on either of mine.
zzdiesel is offline   Reply With Quote
Old September 28th, 2019, 04:44   #9
50harleyrider
Saw no indication of prior removal and also didn't see any indication of thread locker on the fasteners. Most likely 370k miles has somehow caused some corrosion or 'heat treatment" that made them horribly tight.
Old September 28th, 2019, 06:22   #10
thundershorts
Mine had spent a couple weeks as a submarine and they were "tighter than a bulls ass in fly season".
Old October 27th, 2019, 17:59   #11
50harleyrider
Should the 6 flex plate bolts be replaced after removal for a rear main seal job? They are necked down at the top so I assume they are one-time use.
Old October 28th, 2019, 09:41   #12
imo000
imo000's Avatar
Fuel Economy: Good enough
I have reused them more than once with no ill effects.
imo000 is offline   Reply With Quote
Old October 30th, 2019, 17:43   #13
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
On the W8 someone changed these bolts on me to a 12pt 17mm bolt. I had to machine down a socket for clearance. What a PITA.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old November 6th, 2019, 19:27   #14
50harleyrider
tranny swap worked out great except the speedometer isn't working. Should I check and see if it's working in VAG before I dig deeper? Any known culprits with them? where's the pickup? Unfortunately I don't know if it was working before I swapped the good tranny in since the car wouldn't move when I bought it. These wagons are nice. My first one.
Old November 7th, 2019, 04:40   #15
oilhammer's Avatar
Make sure the speed sensor is plugged in, left (driver) side of transmission near the bellhousing/left axle flange area. These use their own specific standalone VSS for the speedometer.
09A torque converter bolts tpitt1946 VW MKIV-A4 TDIs (VE and PD) 3 July 10th, 2019 19:16
Torque for 15MM nuts on torque converter mcquinn VW MKIV-A4 TDIs (VE and PD) 1 July 13th, 2018 04:06
Torque Specs: Torque Converter Nuts blarg VW MKIV-A4 TDIs (VE and PD) 3 July 13th, 2015 13:39
ALH injection pump bolts? Torque to Yield? Torque Specs? marshalldanielp TDI 101 1 November 19th, 2012 10:59
Removing starter on 02 jetta, mounting bolts won't loosen 02jetdi VW MKIV-A4 TDIs (VE and PD) 3 November 28th, 2005 23:06
Page generated in 0.19145 seconds with 13 queries
[Output: 123.29 Kb. compressed to 102.37 Kb. by saving 20.92 Kb. (16.97%)]
