Abacus
That helpful B4 guy
No issues with leaks or slipping, and I've drained some liquid brass (from disintegrating parts when the wrong fluid was used) from a few of them. New fluid significantly helped.
So, are the saying the plain-jane 80w-90 gear oil from O'Reilly's I put in there isn't a great idea?No issues with leaks or slipping, and I've drained some liquid brass (from disintegrating parts when the wrong fluid was used) from a few of them. New fluid significantly helped.
If It's GL5 then it's not a good idea. GL4 is the spec for manual transaxle. The GL5 has stuff in it that is not good for yellow metal parts.So, are the saying the plain-jane 80w-90 gear oil from O'Reilly's I put in there isn't a great idea?
Does the manufacturer say it's ok? Other GL5 manufacturers say do not use in MT's. I don't see how it can be ok when it's GL5 spec?Although for some reason the Lubromoly GL5 doesn't eat the yellow parts up.
Some people use (Lubromoly 75-90)it just fine in their 02A/02J, I have but moved on to the Syncromesh because it was trending as hot like fire brand new best thing ever.
Not to put too fine a point on it, but the company has been operating as Liqui Moly for several years.Although for some reason the Lubromoly GL5 doesn't eat the yellow parts up.
GL4 is the only safe bet I know of other than approved VW fluids. I use the GL4 Ravenol Synth that blauparts was selling, last I knew anyway.
CTN transaxle is too important to have ruined by incorrect fluid, at some point these are going to be hard to find given the numbers of CTN cars that are probably left here now. These are 18 yo at a minimum, probably over 20 yo on average.
Steve
The difference between G50/60/70 is the viscosity - the formulas I've been told are otherwise identical.
Lubromoly 75W90 (LM2048) is GL5, however if you look at the MIL spec, it's the same as the VW recommend spec. I have a letter from the head of application engineering LIQUI MOLY GmbH that confirms that it doesn't harm VW synchros - as long as it's a post 1996 transmission. If you are still uncomfortable with that then stick with OEM fluids .
For years we've only recommended OEM VW fluids or the LM2048. MTL or MT90 is much better suited for the BMW crowd.
YMMV.
-BB
I soaked it down with WD40 and it came of rather easily.....thanks for the infoGoogle: VW Orb of Death -You Tube by Mark Courtenay
No, I'm not wading into this either, it's been debated ad nauseum for years but I just wanted to make sure that it hadn't been forgotten. The collective memory is often not what it should be regarding this stuff.I won't get into the debate over this specific 75w-90, but like I said, I've used it just fine. Lots of people using Pennzoil Syncromesh on tdiclub too.
http://forums.tdiclub.com/showthread.php?t=365844
Yep - that's what folks refer to as "Limp Mode" - if the ECU detects a situation where it believes it is not in control of the turbo it'll drop fueling down to a "safe" level where nothing gets hurt.If have a bad Wastegate actuator on my Turbo.......and it doesn't open, creating more boost. Would my ECU catch that a tune down my car power....maybe at higher speeds. need to know if anyone has experienced this
Well, its starts opening a lower psi, though I didn't have a super accurate gauge. But open fully at 20......thanks for the infoJust pressure on a B4. 20psi is high it should open sooner.
