bbob203
So I just finished up doing a Timing belt service on my 04. I set my torsion value at first without using my OBDELEVEN because I was having issues getting it to connect. I ended up setting it close to the middle to get a good start. Finally got my OBDELEVEN to work so I checked the Torsion value it was -2.94.
It was then I discovered these 2 codes in the OBD-2 module. The car runs great and I have the torsion value set at 2 but the codes have not cleared and come back when I clear them. Any ideas?
P0025 B Camshaft position (bank 2)
Timing over advanced or system performance
P1300 Combustion misfire detected
Low fuel
Low fuel
