Aceshigh21
I've only seen on post regarding this issue and no real or clear answers. The car is a 2002 jetta TDI
When the temp gets below 60 degrees the car will not crank. All lights come on, the glow plugs work and the headlights go out but absolutely no crank. Above 60 degrees the car will crank and start with zero hesitation. Temp drops below 60 and no crank again.
Checked all grounds and connections to starter. No broken wires and no corrosion. Check battery terminals and no corrosion. Battery is 1 year old.
Anyone have this issue before and have a culprit?
Thanks.
Thanks.
