HelenaTDI
- Joined
- May 27, 2007
- Location
- Helena, MT
- TDI
- 2003 Jetta GLS, 2002 Golf GLS, 2001 Jetta GLS, 2002 Golf GLS & Jetta GLS(Parts Store), 2015 Passat 6spd
Hello could use some help from the gurus on MK4's
2001 Jetta TDI auto to 5spd conversion (10k flawless miles since the swap).
Initial condition last week stalled while driving. Would not restart. No glow plug light. Cranks over fine.
Replaced 109 relay. Had glow plug light and car started. Ran ~2 minutes and died. Sounds completely normal when running.
Cleared codes and have glow plug light again. Started up and ran for 3 days before doing the same thing again. Swapped out with another 109 relay same symptoms. Now this time no glow plug light will not start.
Troubleshooting performed:
With 109 relay removed I have 12V at red wire.
With 109 relay removed 0V at blue wire.
Fuse 29 12.4V with key on.
Fuse 34 10.5V with key on.
Fuse 43 12.2V with key on.
Fuse 32 5.7V with key on.
Fuse 37 0v.
Fuse 29 12.4V key on.
Connections at relay socket are good have not pushed out.
Any other suggestions? VCDS scan from this morning. Don't know why all the auto transmission faults now never had that before as I have been running the 5spd for 10K miles in it now. Thanks.
Thursday,18,April,2019,09:37:52:25565
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Mileage: 348890km-216790miles
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 KA
Component: AG4 Getriebe 01M 4761
Coding: 00000
Shop #: WSC 00000
VCID: 79F25D2E63BA8F829A-095A
17 Faults Found:
00258 - Solenoid Valve 1 (N88)
36-00 - Open Circuit
00260 - Solenoid Valve 2 (N89)
00262 - Solenoid Valve 3 (N90)
00264 - Solenoid Valve 4 (N91)
00266 - Solenoid Valve 5 (N92)
00270 - Solenoid Valve 7 (N94)
00268 - Solenoid Valve 6 (N93)
36-10 - Open Circuit - Intermittent
00777 - Accelerator Position Sensor (G79)
27-00 - Implausible Signal
00660 - Kickdown Switch or Throttle Position Sensor
00293 - Multi-function Switch (F125)
25-10 - Unknown Switch Condition - Intermittent
00281 - Vehicle Speed Sensor (G68)
03-00 - No Signal
00529 - Engine Speed Signal Missing
35-00 - -
00300 - Transmission Fluid Temp. Sensor (G93)
34-10 - No Elaboration Available - Intermittent
01236 - Shift Selector Locking Solenoid (N110)
31-00 - Open or Short to Ground
00545 - Engine-Transmission Electrical Connection
00297 - Gearbox Speed Sensor (G38)
03-00 - No Signal
01314 - Engine Control Module
49-00 - No Communications
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066
VCID: 3E788E323A1468BAEF-4AE6
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-00 -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 15 AIRBAG VW5 02 0004
Coding: 12597
Shop #: WSC 00066
VCID: 356A911E0F22ABE23E-4AE6
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 M
Component: A4-KOMBIINSTR. VDO V59
Coding: 07242
Shop #: WSC 23329
VCID: 2C5CB47ADC68EA2A51-5120
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2486871
IMMO-IDENTNR: VWZ7Z0Y2486871
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70E4600A30C0CECA2D-5120
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 060826D22244F07AE7-4AE6
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002r
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 D
Component: RADIO 3CP 0002
Coding: 02401
Shop #: WSC 00066
VCID: 2044504AA0A03E4AFD-4AE6
End-------------------------(Elapsed Time: 06:02)--------------------------
Fuse 37 0v.
www.Ross-Tech.com
75 76
Coding: 00000
Shop #: WSC 00000
17 Faults Found:
03-00 - No Signal
35-00 - -
03-00 - No Signal
Coding: 03504
Shop #: WSC 00066
1 Fault Found:
P1848 - 35-00 -
Coding: 12597
Shop #: WSC 00066
Coding: 07242
Shop #: WSC 23329
1 Fault Found:
Coding: 00006
Shop #: WSC 00066
2 Faults Found:
35-00 - -
Coding: 04096
Shop #: WSC 00066
Coding: 02401
Shop #: WSC 00066
