Old April 17th, 2019, 22:32   #16
Wilkins
Fuel Economy: 4.6/5.6 - 5.3/6.7
I will second IBW. if you see rust behind the mud flap there is probably more in behind. I’d pull the fender liners and look at the seam between the fender and body. Clean out the salty wet mud. Shooting a pressure nozzle in along the top of the rocker panel with the door open is supposed to keep it clean behind the liner - if done often enough.
2005 Jetta Wagon: Evo skid plate, Kerma Tune, Moog VR6 front springs, Koni Reds, Jeff's HID's, Upgraded door switches!. MKVI: Containflo+Pureflo, Rear Tiggy springs and B6 Billies, Xenon w LED, AFS, 087T BCM
Wilkins is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Cptcrnch
Injection pump and crank pulley surface rust? marshalldanielp TDI 101 1 November 18th, 2012 09:39
Cylinder surface corrosion/head gasket surface preperation dislexicmofo VW MKIV-A4 TDIs (VE and PD) 32 March 2nd, 2012 12:05
Rockers starting to rust. Rockerguard or Plasti-dip? flatlanded Upgrades (non TDI Engine related) 7 July 19th, 2011 20:29
Rust on Rockers bigmacblb VW MKIII-A3/B4 TDIs 6 October 21st, 2010 03:14
Jetta anti-rust treatment golightfoot TDI 101 10 March 10th, 2003 05:30
Page generated in 0.12800 seconds with 12 queries
[Output: 48.87 Kb. compressed to 46.08 Kb. by saving 2.79 Kb. (5.72%)]
