Old September 19th, 2017, 05:18   #1
Aquaticmind
Aquaticmind's Avatar
Location: Wheeling, WV via Athens Georgia via, Bainbridge Is. Wa, via Carbondale IL, via Asheville NC
Fuel Economy: good
Default Upgrade front sway bar question - Lifted Wagen
Moved from TDI 101
Hi folks,
I've been running around with a lifted 03 Wagen for years. I have a 22mm HR rear sway bar on it and while I had thought about upgrading the front sway bar years ago, I had never really needed to not gotten around to it.
Now I live in WV and my drive to work is on a windy 2 lane road, which has made it abundantly clear that I need a stiffer front sway bar.
Any suggestions on what size front sway bar to go with be helpful? Would an aftermarket 22mm Einbach be good or would it only be worth it if I went with something like a 26" H&R.
Any feedback would be appreciated. I drive down dirt roads on a regular basis for camping and what not, but mostly its a commuter car.
Cheers
2003 Wagen, 2" lift, auto front springs, panzer plate, pp520 injectors, RCII+, ASR
Aquaticmind is offline   Reply With Quote
Old September 19th, 2017, 12:36   #2
Aquaticmind
Fuel Economy: good
I'm not getting much response from my original post so let me change the question.
Does anyone have experience with an upgraded front sway bar?
Anyone running a bigger 26mm H&R front sway bars?
Any downsides to going with the 26mm bar?
Old September 20th, 2017, 04:30   #3
bobbiemartin
I can't speak to the sway bars, but I may suggest another alternative. Audi TT lower control arms and hubs will allow you to dial in more negative camber. I did that on my Golf and I'm very happy with the results. Tires also make a big difference, as do struts, springs, bushings, etc. If you really want to go all out, fit a limited slip. That makes a world of difference, all of it good!
Bobbie Martin Jacksonville, FL
bobbiemartin is offline   Reply With Quote
Old September 26th, 2017, 18:18   #4
Aquaticmind
Fuel Economy: good
I'm already running the TT bushing and I'm not sure a LSD would make the difference in body roll going around corners.
The LSD is in the plans so I make it to work in winter.
Old September 26th, 2017, 18:58   #5
bobbiemartin
TT bushings are not the same as TT lower control arms & hubs. Instead of using a rear sway bar reduce understeer, try to increase front grip and then add the rear sway if needed. The LSD may not help body roll, but makes a huge difference in handling and when you can get on the power. I think once you add the LSD you will be pleasantly surprised.
Old September 26th, 2017, 20:30   #6
Rrusse11
Aquatic,
Like Bobby, I highly recommend the LSD, especially if you're gonna' be tackling twisty, snowy, roads. An expensive option,
but I guarantee you'll never look back once you've got one.
I strongly advise doing that before anything else.
I'm contemplating upgrading my front sway bar, and installing a rear. But I'm looking at those to firm up the car for towing. Got the pair cheap from somebody cleaning out their garage. If I don't like 'em, I'll pull 'em off.
I'm happy with my current setup, offset spacers, rear Koni Reds dialed up 25%. Bushings are good condition stock. My mechanic reckons that you need a bit of give for comfort and stabilising the diesel vibrations. Good tires and alignment will go a looong way for front end driveability.
Read the "What is Handling" thread, lots of opinions and great advice. There is no magic fix, you have to pick and choose to
create a setup that works for your driving style, needs and conditions. You do have to be as objective as possible, and realistic
and aware, of what it is you're trying to achieve.
My $.02,
R*2
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3bar MAP:2.5" Exhaust: Koni Reds HD Springs, ~1"lift:VR6 fr swaybar, Top strut & rear tie bar: XXIO Racing Rims, 215/55ZR16 GMax AS03's, 10mm/20mm spacers, 35# @: Ventectomy: Atlas skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: Bosal Hitch: VW racks:
Rrusse11 is offline   Reply With Quote
Old September 26th, 2017, 21:22   #7
UhOh
UhOh's Avatar
I know we're talking front suspension bits here but I'm a total advocate of/for Cupra R rear axle bushings. I think that it makes the rear a lot tighter, thus reducing the transference of sloppiness to the front (the tail wagging the dog).
Question for anyone with a lifted VW, front sway bar upgrade Aquaticmind TDI 101 1 September 19th, 2017 13:56
front sway bar upgrade? dan30thz28 VW MKIV-A4 TDIs (VE and PD) 3 April 23rd, 2014 14:32
Front sway bar -vs- Rear Sway bar ChippedNotBroken Upgrades (non TDI Engine related) 25 November 28th, 2010 06:53
MK4 TDi Front sway bar question cdnalpina Upgrades (non TDI Engine related) 2 October 13th, 2009 17:51
Lifted, stock, rear sway bar? mannytranny Upgrades (non TDI Engine related) 3 November 20th, 2007 14:19
Page generated in 0.16024 seconds with 11 queries
[Output: 84.67 Kb. compressed to 73.82 Kb. by saving 10.85 Kb. (12.81%)]
