Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old July 3rd, 2017, 19:07   #16
carsaremytoys
I almost pulled the trigger. Everything was good until halfway through the test drive coming to a stop the oil pressure dropped all the way down and the light came on just for a second. Got back, killed the engine and waited 5 or so minutes and checked the oil. Nothing registered. He told me it was due for it's 3k mile rotella t6 oil change and there was oil all underneath, but I understand it's a truck that is going to leak and fling oil everywhere. The factory turbo only had 20k on it. I figure the engine was burning a good amount...
carsaremytoys is offline   Reply With Quote
Old July 3rd, 2017, 20:14   #17
turbobrick240
turbobrick240's Avatar
Oh man. My lowly 7.3 with 210k holds its oil just fine. You'll find a better one.
Old July 3rd, 2017, 21:00   #18
tadawson
There is absolutely nothing in a properly maintained Cummins that should drop oil, especially at that low a mileage. Short of someone goofing the filter gasket, not much you can carelessly get wrong . . .
tadawson is online now   Reply With Quote
Old July 4th, 2017, 06:38   #19
\/\/0J0
\/\/0J0's Avatar
Fuel Economy: At least 2x that of my TJ
The truck does have 222k on it. I'm not sure what was meant about factory turbo with 20k..?
There are a couple of places that oil likes to come out of B series engines. The first is the tappet cover, located on the driver's side behind the injection pump, it has a gasket that can be quite finicky to seat properly. The second is the timing gear train cover. Despite having a gasket available for the application, the accepted practice is to use rtv to seal it up because of the likelihood of leaks developing from using the gasket alone.
Still should not be leaking so much that is doesn't register on the dipstick in less than 3k after being refilled.
Sent from my mobile look-at device
I miss my TDi
"Those willing to sacrifice Liberty for Security deserve neither" -Ben Franklin
\/\/0J0 is offline   Reply With Quote
Old July 4th, 2017, 06:41   #20
carsaremytoys
I meant factory oem, replacement. Not original
Old July 4th, 2017, 10:38   #21
tadawson
Sounds like maybe a dingus did a valve lash adjustment and botched putting the covers back on (or reused old gaskets far too many times)?
Old July 4th, 2017, 11:07   #22
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
GAD
No oil on stix?
Seller did not even prep the unit with full oil?
IMO, seller is no one for you to trust.
Friendly advise
... run as fast as you can
... look else where.
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old July 4th, 2017, 12:19   #23
carsaremytoys
What's GAD?
And I disagree about the honest part. He passed my test of many complicated questions.
People that "prep" their cars are hiding something.
Old July 4th, 2017, 13:40   #24
2015vwgolfdiesel
What's GAD?
It's your $$$$s and your future -- Happy motoring
Old July 4th, 2017, 13:43   #25
carsaremytoys
You are not at all contributing to this world.
Old July 4th, 2017, 13:45   #26
tadawson
Well, as they say . . . never attribute to malice that which can adequately be explained by stupidity. Sounds like the owner just didn't care much about this truck, and just didn't have the mental firepower to do simple things like fixing leaks and checking oil level . . .
It's hard not to wonder how many times he has starved it for oil, and what kind of shape the bearings are in . . . heck, that might be why he lunched a turbo - they are not at all fond of running dry.
All in all, I think what we are all saying is that there are enough things of concern here (for whatever reason) to not even come close to that asking price bei g reasonable, and/or make a buyer run away . . .
Old July 6th, 2017, 12:52   #27
crazyrunner33
crazyrunner33's Avatar
Low oil is an automatic no for those engines. It's best to find a truck that's close to stock and well maintained, preferably with paper air filter. Just because the engine is one of the most legendary engines that is hard to screw up, it doesn't mean that it's immune to neglect. Personally, I'd run from any Cummins with a K&N; been there, done that, got the T-Shirt, and the $7,000 dollar rebuild. The transmission is also not bulletproof, even the NV4500. The NV4500 is weak, plus the synchronizers are more sensitive to oil type than the PD TDI camshafts.
As a 12 valve owner, I can admit that they are not the kings. The 6.7 and '06 to '07 5.9 are the true kings of power on the street. The insanely wide range of dynamic timing allows them to spool much larger turbos without much smoke and significantly faster response. You can daily drive a 69mm turbo and spool that'll support over 750 hp better than a 12 valve with a smaller turbo for 500 hp. The CP3 in the common rail is just as reliable as the P7100, and the '06 and newer injectors are very reliable, they do not have the stigma of the first gen common rails. A 12 valve needs a small set of compounds and a built auto to make a fun streetable 600 hp or more.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old July 6th, 2017, 17:33   #28
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
cummins is the best engine in a junk dodge
7.3 is a tick below the cummins but in a ford truck that won't fall apart around the engine
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old July 8th, 2017, 19:11   #29
carsaremytoys
I know that the Dodges fall apart due to rust.
Old July 8th, 2017, 20:28   #30
tadawson
Yeah, the engines just grenade, rendering the rest irrelevant . . . .
Frankly, I think the newer Ram's are better in that regard . . . I have a 2011, and not a mark on it (granted, in TX).
moving to snow country TDI wyrmrider TDI 101 11 May 22nd, 2015 15:33
What Is a good school for VW or Diesel Cars/Trucks 1985Wolfberg VW MKIII-A3/B4 TDIs 14 March 26th, 2011 19:03
Caution - Students with Moving Trucks Lineman TDIFest 2004 2 September 2nd, 2004 21:19
Out of Country Diesel Trucks Go North Non VW Group Diesels 19 February 25th, 2003 10:56
Out of Country Diesel Trucks Go North TDI 101 13 February 22nd, 2003 21:45
Page generated in 0.16527 seconds with 11 queries
[Output: 129.83 Kb. compressed to 108.83 Kb. by saving 21.00 Kb. (16.17%)]
