Old September 19th, 2017, 14:37   #31
AndyBees's Avatar
Default Comparing Inside Diameter of OE vs SS Braided Hose
I have practically everything it takes to build an ALH engine. I've looked at possibilities for an oil feed tube/line/pipe over to the Turbo for this future engine...
Below, are pics of the OE tube vs the eBay SS Braided Hose. Can someone assure me (us) the smaller diameter SS Braided Hose will provide adequate oil for the Turbo?
Below, is a comparison of the SS Braided Hose end at the Turbo (sorry about the focus). It appears the fitting in the Turbo is roughly the same size as the SS Braided Hose inside diameter (ID).
Below, or is the ID of the SS Braided Hose the same size as the fitting in the Turbo?
Experienced hands, tell us what you think!
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
AndyBees is online now   Reply With Quote
Old September 19th, 2017, 14:53   #32
I had a conversation with our Garrett tech support rep the other day in reference to a PD turbo that had failed. The reason for failure was "insufficient oil flow" causing excessive heat and eventual turbo failure. What was interesting to me about the conversation was that the Garrett rep talked about oil flow, not pressure. He said that pressure can be fine but if flow is inadequate the turbo will overheat.
We don't carry braided hoses because I could never be sure that they would flow enough oil to support a warranty claim if a car with one has a failed turbo. We know that the OE lines do flow enough oil. And honestly, OE lines, when installed properly, work fine for a long time. I've replaced the oil feed line once in my wagon over the course of 350K miles and 4 turbos. And it hadn't failed. I just thought I wouldn't tempt fate by using the one that came with the car during the most recent turbo install.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old September 19th, 2017, 22:33   #33
After reading this thread, I am content with the braided oil feed line I recently purchased from KermaTDI. It doesn't use the banjo fitting. I'm guessing it provides just as much flow or more than the stock tube type line.
2005 Golf GLS TDI
2010 Jetta TDI(sold to VW)
thorp is online now   Reply With Quote
Old September 20th, 2017, 14:00   #34
Fuel Economy: 40-ish
Thorp, I agree that a straight fitting on a braided oil line will not restrict the
flow if it maintains the hose's ID. Using high-pressure hydraulic fittings and
adapters with smaller ID's might create a restriction, though.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Turbo oil feed line Kris1987 VW MKIII-A3/B4 TDIs 5 June 1st, 2015 20:48
05 TDI Golf turbo replacement pics and oil feed line replaced w/ steel braided line. Kruso VW MKV-A5 Golf/Jettas 6 May 8th, 2013 20:52
Turbo Oil Feed Line microsoot VW MKIV-A4 TDIs (VE and PD) 10 May 10th, 2012 11:49
Turbo oil feed line. Do u have one? willyraz TDI 101 7 January 23rd, 2008 18:32
have a look at your turbo's oil feed line because laminated VW MKIII-A3/B4 TDIs 3 October 22nd, 2004 14:10
Page generated in 0.12732 seconds with 11 queries
[Output: 66.73 Kb. compressed to 59.97 Kb. by saving 6.77 Kb. (10.14%)]
