Old June 4th, 2017, 18:03   #16
Prairie Chicken
Same thing happened to me but on the back side... this was after a turbo change and couldn't find the line holder for the rear bracket. Lesson learned. New oil feed line and got a new holder from idparts. It is solid now.
I thought about the SS line but didn't pull the trigger. Maybe next time.
Prairie Chicken is offline   Reply With Quote
Old June 4th, 2017, 23:36   #17
Millennium Falcon
Yeah this isn't something I had thought about much but boy once it fails on you it kinda makes you paranoid. My car also was missing the clamps so Im guessing the vibration took their toll. I stole the clamps of my parts car. I do believe many of the ss lines are the same. I read a thread the other day about one of the $90 kerma lines blowing so even the "expensive" ones can fail. I will let you know how mine looks. It wasn't the cheapest one I could find but it wasn't $90 either.
2003 Jetta TDI wagon, 5-speed, swap, Sprint520 nozzles 165k
2004 passat 1.8t auto 104k
Millennium Falcon is online now   Reply With Quote
Old September 16th, 2017, 11:40   #18
ranagon
The oil feed line on my son's 2005 BEW wagon cracked yesterday, right at the banjo bolt fitting on the oil filter.
I didn't find any oil feed line clamps installed. The preceding discussion pretty well establishes that they are essential.
Does anyone have a picture of where they're supposed to go? ETKA shows the parts, but not the location.
Thanx.
ranagon is offline   Reply With Quote
Old September 17th, 2017, 00:28   #19
Nevada_TDI
I only have one oil line clamp and it attached to the driver's side exhaust housing bolt facing the firewall that looks like it shouldn't be there; tomorrow when it is light I will take a picture if nobody else has yet.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old September 18th, 2017, 16:15   #20
Beaker80
I'm going to be replacing the seized turbo on a 2006 Golf BEW engine and I want to replace the turbo feed and drain lines as the car has 300K Km's on it. I was thinking of getting this kit as it has both lines and is substantially cheaper than buying them separately;
http://www.ebay.com/itm/BEW-Turbo-In...19.m1438.l2649
Any thoughts? Will the original lines be OK with new copper washers and gaskets?
Beaker80 is offline   Reply With Quote
Old September 18th, 2017, 16:50   #21
Vince Waldon
Vince Waldon's Avatar
Even before talking about if that kit will work, search here on the seller aka "Prothe".
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old September 18th, 2017, 17:31   #22
AndyBees
AndyBees's Avatar
Yeah, your used hard line, banjo copper seals, gaskets, etc., would be superior over the Prothe product, in my opinion. The Gasket Kit you see in the middle of the photo sells by him for about $10.00. So, he's charging close to $50.00 for an unknown quality hard line.
I'd be far more inclined to re-use the old hard line as well as your used gaskets than trust that kit. The one on my Vanagon ALH Engine has been off and on numerous times with no issues...... even re-used the gaskets with no issues. Better support for the hard line than OE is the key.
EDIT: And, why would you need a new drain pipe? Seriously!
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
AndyBees is online now   Reply With Quote
Old September 18th, 2017, 19:10   #23
jimbote
jimbote's Avatar
the problem is not the factory steel line, it's that securing clamps were not reinstalled after service work or the turbo was replaced ... braided lines will fail too if not secured from excessive vibration
Old September 18th, 2017, 19:45   #24
Beaker80
I did a search for user "Prothe" and a lot of older threads. Is he or one of his many alias' behind the ebay store?
I'm asking here about changing lines as a proactive measure. I don't know why this turbo is seized as I bought it this way. The car does run and drives but obviously way down on power.
So I'm asking members here for advice. When I take the feed and drain line off I will clean and inspect them. If they are good they will go back on. Does the scavenge line get coked up? If so what's best to clean it with? Can the copper washers be reused if still flat? This is all original hardware as I know the previous owner and she had the car from new.
Old September 18th, 2017, 20:23   #25
AndyBees
AndyBees's Avatar
As I stated above, I've removed and re-installed the hard oil line to the Turbo on my ALH numerous times, including the copper seals without issue. Some people use a propane torch to puff up the copper washers. I've never tried that. I've put over 80k miles on it in my 84 Vanagon... for a total of 209k miles. I have no plans to replace it.
I agree with Jimbote's assessment.
During the summer of 2016, my fabricated aluminum brace, installed at the OE location (back of block above bell housing) broke. I found it broken after returning from a 12k mile road trip. That gave me some insight as to the amount and intensity of the vibes these engines dish out. I have my aftermarket oil pressure gauge sending unit mounted on the end of a grease gun hose and suspended by a spring. Everyone of them would die in less that a month due to vibes if they were screwed into a T at the oil filter housing.
So, proper bracing (in rubber) is the key.
The drain hose is not problematic !
Old September 19th, 2017, 05:06   #26
Rrusse11
"Some people use a propane torch to puff up the copper washers"
What you need to do is anneal the copper, ie. soften it. Heat to red hot,
and immediately quench in cold water, quite the opposite of steel.
Copper work hardens, the heat and pressure those washers undergo
in a motor compromise its crushability, necessary for a good seal.
Clean flat surfaces are obviously critical as well for it to do its job.
For my upcoming turbo install I'm planning on using a braided SS line, but I will be paying close attention to some kind of flexible support, especially at the fitting ends.
RC Stage 4: 11mm pump, 17/22, 3bar MAP:2.5" Exhaust: Koni Reds HD Springs, ~1"lift:VR6 fr swaybar, Top strut & rear tie bar: XXIO Racing Rims, 215/55ZR16 GMax AS03's, 10mm/20mm spacers, 35# @: Ventectomy: Atlas skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: Bosal Hitch: VW racks:
Rrusse11 is online now   Reply With Quote
Old September 19th, 2017, 05:46   #27
Beaker80
Thanks everyone for the input. I will reuse the originals after inspecting them. I will anneal the copper washers. AndyBees; good advice - thanks.
Old September 19th, 2017, 10:59   #28
Prairie Chicken
Thanx.
Ranagon... here is a pic of my 04... the clamp is on the drivers side where it curls around the head.
Old September 19th, 2017, 12:35   #29
Nevada_TDI
There is a new braided SS line available on ebay for less than $25.00; I own one. I will see if I can find the link.
_______________
Old September 19th, 2017, 12:46   #30
Nevada_TDI
double post
_______________
Turbo oil feed line Kris1987 VW MKIII-A3/B4 TDIs 5 June 1st, 2015 21:48
05 TDI Golf turbo replacement pics and oil feed line replaced w/ steel braided line. Kruso VW MKV-A5 Golf/Jettas 6 May 8th, 2013 21:52
Turbo Oil Feed Line microsoot VW MKIV-A4 TDIs (VE and PD) 10 May 10th, 2012 12:49
Turbo oil feed line. Do u have one? willyraz TDI 101 7 January 23rd, 2008 19:32
have a look at your turbo's oil feed line because laminated VW MKIII-A3/B4 TDIs 3 October 22nd, 2004 15:10
Page generated in 0.16816 seconds with 11 queries
[Output: 127.38 Kb. compressed to 106.31 Kb. by saving 21.07 Kb. (16.54%)]
