Old September 19th, 2017, 15:29   #781
forrest resto`s
Hey 2micron.. I have been reading about your products for years..and must admit.. I am somewhat confused ..what is available NOW ( if anything) for my 2011 jetta tdi as far as the filtration for my hpfp? I am keeping my car (going for the fix) and need some peace of mind if possible! Thanx.. Forrest
forrest resto`s is offline   Reply With Quote
Old September 19th, 2017, 16:55   #782
2micron
TDI(s): None
Hello Forrest,
Thank you for asking!
I have a couple options for you:
Right now:
CP3 pump kit. It's more than well proven to allow you to forget the HPFP concern and have the ultimate piece of mind for fuel system reliability. 100% bolt on, plug and play with no ECU modifications required. Works perfectly on a factory emissions car up to and beyond our current "stage(s)" of tune.
Many report easy installation, factory look, faster starts and a very minor increase in fuel economy. Comes with the One Micron filter head, filtering your fuel after the factory fuel filter, giving you the cleanest, best chance at water free fuel fed to your new pump and injectors.
Option #2
The original "Contain Flow" filter kit. New one piece design with no fittings to leak. Uses the CimTek 70025 one micron filter to filter the return fuel from your factory HPFP, protecting your low pressure system from pump contamination. These are available right now as well.
The Contain Flow kit above should be paired with the original Pure Flow kit that is coming back soon..... very soon.
It's also a one piece design, no fittings to leak, see pictures a few posts back.
Send me an email if you wish and I can give you pricing options.
Thank you,
Andrew
tdi2micron@yahoo.ca
2micron is offline   Reply With Quote
Old September 20th, 2017, 10:30   #783
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Haven't installed mine yet because one of the most "reputable" but aloof (ie IMPOSSIBLE TO CONTACT) tuners told me it would need to be re-tuned....
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
schnellvw.com
GTiTDi is offline   Reply With Quote
Old September 22nd, 2017, 22:25   #784
LeeM
Fuel Economy: 55.2/50.1/41.9
Does the CP3 fit the Passat?
LeeM is offline   Reply With Quote
Old September 22nd, 2017, 23:03   #785
JSWTDI09
JSWTDI09's Avatar
The 2micron mods (pure flow and contain flow) have absolutely zero effect on fuel delivery to the cylinders. Fuel pressure, injector timing and quantities, and fuel flow are completely unchanged. There should be absolutely no need for any change in a tune because there is no change to the flow of fuel after it leaves the HPFP.
The contain flow device is only there to limit damage if the HPFP fails (it prevents shrapnel from returning to the tank and recirculating through the system).
The pure flow system actually only separates the flow of fuel to the high pressure side of the pump from the fuel flow to the low pressure side of the pump. Most HPFP failures occur in the low pressure side. This mod prevents the shrapnel from any failure from getting into the high pressure part of the fuel system (the fuel rail and the injectors mainly).
Both mods are designed to limit the carnage caused by an HPFP self-destructing but each one protects a different part of the fuel system.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old September 23rd, 2017, 08:14   #786
2micron
TDI(s): None
Yes!!!!
I have a specific Passat CP3 pump kit now. Contact me for details. Same 100% bolt on and plug and play as the Jetta/Golf cars. The kits is basically the same, just had to allow for clearance around a coolant line.
Thanks !
Andrew
tdi2micron@yahoo.ca
Old September 23rd, 2017, 08:20   #787
2micron
TDI(s): None
Have Fun!
Don
Yes, thank you Don, you nailed it!!
The statement was in regards to a CP3 pump kit. Which does not required any additional tuning with the new pump. A bone stock, factory emissions car works perfectly with the CP3 kit, as well as any level of Malone tuned cars. There are many, many owners that would be happy to give feedback.
When we exceed stage 3, Malone has developed a specific Stage 3.5, geared to the CP3 output. Best to allow a Malone representative to comment.
Thank you,
Andrew
Old October 20th, 2017, 10:45   #788
2micron
TDI(s): None
Yes, new kits coming!
I have developed a new Pure Flow adapter. One piece, modular aluminum block with no additional fittings, lines or places to leak. This will make installation much easier. It is designed to fit all the 2.0 4 cylinder CR motors. Yes, Passat and the latest EA-288 (2015 Jetta, Golf and Wagon)
There also needs to be a return filter for the CR motors. My original "Contain Flow" filter will still work for most, but the new EA-288 (2015 Jetta, Golf, Wagon) will require a remote filter on the underside, which I am developing.
Here is a sneak peak of the new Pure Flow (temporarily in plastic):
Thanks all!
Andrew
Hello All!
New style PureFlow kits are Ready!!
It is one piece, modular, solid aluminum anodized block with no external lines or fittings or seals. The modular block is ported internally, eliminating the previous external tubing and fittings of the first generation PureFlow.
These are designed to fit the first generation 2009-2014 cars, as well as the new 2015's.
No extra fittings, tubes or hardware is required.
Installed on a 2015 GSW. You can barely notice it is there!!!!
Also, New Style filter head for 2009-2014 cars. Same new modular style with no fittings and machined in one piece hose barbs.
Filter heads (both kits for return Flow protection and main fuel feed protection) coming soon for the 2015 MK7 cars.
Contact me if you wish to get one of these new modular style kits,
Thank you,
Andrew
Old October 21st, 2017, 08:58   #789
Terry270
That is some amazing work man!
2003 2dr Golf TDI-R32 bumpers, sideskirts and wheels, VNT17
2010 Audi A3 TDI-CR170, Malone stg3, ARP headstuds, GLI Brakes, 2micron fuel and serpentine belt protection kits
Terry270 is offline   Reply With Quote
Old October 21st, 2017, 20:00   #790
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Wow, would like to see the machine tool that cuts the filter heads. Specifically how those barbs are cut. Nice work Andrew.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old October 23rd, 2017, 23:27   #791
turbobrick240
turbobrick240's Avatar
Neato! Funny how one guy in Canada can come up with more elegant design solutions than entire teams of German engineers.
Old October 24th, 2017, 18:29   #792
freyguy
Fuel Economy: ~40 mpg
Thumbs up
"Like" with a thumbs up.
CP3 pump installed, 2microntech kits from 60k to 120k miles, CarStyle4You switch and covers, inside trunk LED lights, winter set of Blizzak WS70 P205/55/R16 with Sport Edition F7 Wheels, beverage of choice: Roadmaster XL
freyguy is offline   Reply With Quote
Old October 24th, 2017, 19:17   #793
2micron
TDI(s): None
Thank you all for the nice comments folks!!
Here are a couple more pictures of the special one piece hose barbs.
All the best!!
Andrew
Old October 30th, 2017, 18:52   #794
travis45
travis45's Avatar
What the...
Cool!
14 Sportwagen TDI CR170 Frankenstien hybrid 2056 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD, GTB2260vklr, Colt billet cams w/upgraded springs, ARP Headstuds.
travis45 is offline   Reply With Quote
Old October 30th, 2017, 19:06   #795
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Thanks for the pictures Andrew. I agree, they are cool.
Diesel Power Tuning Modules for VW Common Rail at kermaTDI VailPowder Vendor & GroupBuy items for sale 32 March 18th, 2015 17:18
VW utilisera un common rail en 2008? Nico3d3 Quebec 4 June 26th, 2007 16:41
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
VW move to Common Rail TDIdragon TDI News/Tech 81 June 12th, 2006 05:55
VW TDI common rail flappie VW MKIV-A4 TDIs (VE and PD) 77 May 25th, 2002 22:08
Page generated in 0.40149 seconds with 11 queries
[Output: 135.44 Kb. compressed to 114.42 Kb. by saving 21.02 Kb. (15.52%)]
