We (me and the missus) recently aquired a 2.0 TDI 4motion 140 hp, 116K km on the clock, from our father in law. 6-speed, has a good ompf to it, i like it even though im a rotary engine fanatic. The wastegate has a tendency to get stuck now and then(wg arm gets stuck, has to be regularly lubed to work), venting all boost pressure. It resets when key off and on. Now, i _COULD_...swap the wastegate and WG-arm... but... the powerhungry retard in me does not want that.... Also.. the missus does not know that one can swap the WG arm only, as her father told her before we got it that the turbo is on its last legs...*
Ive seen that Darkside developments does some nice turbokits upping the power to 230ish bhp when ecu is remapped, and they are quite tempting. Has anyone here done a diesel powered 230ish bhp with this or similar kit? What can you recommend? Is there any major risks involved in this appart from the regulars like added strain on drivetrain etc? When will the injectors, dieselpump etc top out? I have no wag diesel tuning experience, so help is needed
