Farfromovin
Torque Addict
Background--Car is an 03 ALH with 58k miles. I purchased it used from a private party at 48k miles. Immediately installed PP764's, clutch upgrade, alligator tune. Went on to purchase a hybrid 17/22 turbo, intake, exhaust, intercooler, lift pump, larger TIP, W/M (50/50), 11mm IP, and switched to R520's.
Symptoms--After my dyno I suspected something was wrong with my fueling. I had fueling maxed out in the tune and with the race nozzles I should have been smoking like a train but it was clear once the turbo spooled up around 2500 rpm. Swapped out the lift pump, fuel filter, went back to different nozzles (PP764), no change. I was assuming it was the IP and was on my way to the regional guru (KROUT) when the problem happened. Running up a hill at about 20psi in 5th, egt's up to about 1200, about 90mph, I saw a faint blue hue behind me. Let off the throttle while I was staring in the mirror to see if that was really blue smoke but it was hard to tell. Gave the go pedal a little blip and sure enough saw a bluish cloud forming behind my car. Coasted down to speed and merged onto the shoulder and maintained speed at around 50mph or so and the car started running rougher and rougher. Decided the car had a serious problem and would need a tow back to the house. Shut it off and towed it 50 miles back home.
Problem-- Had KROUT make the trip across the state (thanks again) for a compression check and a teardown. Cylinders 1 thru 3 A-OK, got to #4 and nothing Pulled the head to find this in #4:
Apparently, the wrist pin gouged the cylinder wall pretty severly. My guess is the wrist pin let go first, and when it gouged the cylinder the added stress caused the clean crack all the way through the center of the piston. The cylinder head appears fine. Car never overheated and valves look clean. Timing belt and everything were ok after the incident. My question to those in the know is two fold: 1) Am I right in guessing the wrist pin let go, causing the crack? and 2) Why would the wrist pin let go?
