Ironforger
- Joined
- Feb 18, 2003
- Location
- Lawrenceville, NJ.
I Noticed my IP was getting noisy, so I checked the timing, and it was too far retarded. I adjusted the IP sprocket, and got the timing back to dead on, but the IP is still noisy as hell. It just sounds way to loud to me, like a loud tapping racket.
Also, the idle seems to flutter a little. Otherwise the car funs fine, very powerful.
Co-incidentally, this is the second time in 6 months that my timing has mysterously changed. The last time, it was WAY advanced, like off the chart advanced. Yea, I torqued the sprocket bolts mighty tight each time.
Now, I don't know the history of this IP, since it is a replacement. It was changed out before I got the car in an effort to diagnose another issue (which has since been resolved and unrelated to the IP). So, I do have the original IP, which has about 100k on it.
Opinions/suggestions? I'm told that the IP may be going. Are there any vag tests/readings I can do to check the IP? I'd like to be sure it's bad (if possible) before changing it out?
Thanks!
Thanks!
