I just pulled up a code saying that my left rear wheel speed sensor has an intermittant signal. The ABS light is on in my instrument cluster. Can anyone tell me anything about this? It's a 99.5 NB TDi
Check inside the connector for good connection and see if it is green--also see if wheel bearing is loose--and wiring to it--if all is well you most likely need a sensor
My front-right has been faulty for the last 40K miles after doing some suspension work. I would also suggest using a little dielectric grease on the connectors.
