lirunaway
- Joined
- Feb 17, 2010
- Location
- Mooresville, NC
- TDI
- 2006 VW Golf TDI, Model Year:2006 Code:6 MFG:07/05 Vin:9BWGR61J364004114 Sales Model:9B1 538 Description:1.9 TDI High 100 Engine:BEW Type:TD CCM:1896 KW:74 Description:Pumpe-D... Transmission:GPC Type:A Number:09AH GVWR:4097 Front:2269 Rear:1850
I did an autoscan and got the following:
1 Fault Found:
19463 - Camshaft Position Sensor (G40): No Signal
P3007 - 000 - - - Intermittent
Freeze Frame:
RPM: 1806 /min
Torque: 204.0 Nm
Speed: 61.0 km/h
Load: 61.2 %
Voltage: 14.44 V
Bin. Bits: 00001000
Idle Stabilization: 0.0°KW
(no units): 48.0
Readiness: 0 0 0 0 0
Saturday,06,August,2011,10:40:46:26005
VCDS Version: Beta 11.3.0
Data version: 20110601
Address 02: Auto Trans Labels: 09A-927-750.lbl
Control Module Part Number: 09A 927 750 BL
Component and/or Version: AG5 Getriebe 09A 0262
Software Coding:
Work Shop Code:
VCID: 76E8FAFE7DE2
1 Fault Found:
01045 - Tiptronic Switch (F189)
27-10 - Implausible Signal - Intermittent
Anyone have any experience with this?
1 Fault Found:
Freeze Frame:
RPM: 1806 /min
Torque: 204.0 Nm
Speed: 61.0 km/h
Load: 61.2 %
Voltage: 14.44 V
Bin. Bits: 00001000
(no units): 48.0
Software Coding:
Work Shop Code:
VCID: 76E8FAFE7DE2
1 Fault Found:
