WallaceMI
Hi,
A couple days ago the engine light on my Jetta TDI SPW (MY13, 42k miles) came on. I read out the error code P048C ("Exhaust Pressure Control Valve Postion/Sensor/Switch Circuit Range/Performance").
I found out that this is unfortunately a common issue with the exhaust flap in many TDI engines and there is even a TSB and Extended Warranty issued by VW but only for MY09-12.
I went to Ralph Thayer (VW Dealer/Service) in Livonia, MI and they told me that my MY13 is not covered under the extended warranty and I most likely would have to pay the repair of ~$400. I'm challenging them right now to cover it under warranty / good will. Let's see if this works out.
My question is (in case they don't cover it) how difficult is to fix that issue on your own? Did someone ever did that here and can give me some instruction? Does someone has the TSB 2031583 /5 as a PDF and can share it with me (please PM me and I will send you my email address)? I could't find it using Google.
I appreciate your help!
