emdiesels
Owners - I am new to the club but have been reading posts and articles as a non member. Have owned several 240D Mercedes and 2 older jetta diesels. I now have a 2002 TDI.
Problem: Just replaced timing belt & head, ground valves replaced lifters. Will not start.
1) Sure timing is OK
2) Primed pump.
Symptom:
After troubleshooting determined that high pressure pump is intermittent. With injectors connected to lines and injectors out of cylinders to atmoshere, when cranking I get 2 or 3 squirst out the injector pintle from random injectors then nothing.
With injectors installed the car will fire a few times then stops. Seems to be in conjunction with the few good injector squirts. (confirms timing and compression is OK)
I have vacuumed pump/filter with a Mighty Vac and cracked the injector lines as prescribed in the several threads I have read.
When Vacuuming (sucking) the pump on the return side it always is sucking some air bubbles but fuel does flow. Also there is always a air bubble in the supply line (clear) between the filter and inlet to pump.
It seems as though the pump still is air bound. I have visually cheched for a suction leak with nothing found. During the repair process the pump high pressure and the inlet and outlet lines were disconnected for ~ 1 month and so the potential for air to get into the pump.
Please any ideas would be greatly appreciated.
2) Primed pump.
Symptom:
