tdi2003
Hi
First post here..
I am in the UK...
I have had my 2003 Passat TDI for about a year now, recently I had the Altenator pulley come off and as it had worn out the threads I couldnt get a new pulley so needed a new Altenator (it was re-conditioned couldnt afford a new one) , during this time the battery went totally dead and all the clocks re-set (didnt have to enter a code for the radio which is strange)
I have a few issues since then , but the main one for now is:
When i press the fob once it unlock the drivers door as normal
Pressing it again used to unlock the other doors, however this does not happen. The lights flash , and I can hear something in the drivers door, but none of the other locks pop up.
If i then press the button on the drivers door to unlock the doors it works fine. The boot (trunk) will open with the Fob fine, and they all lock with the fob fine.
I have read around on the Internet about what to do and the main things i can see are:
Disconnect the battery , as this will supposedly fix this issue.
Once answer something along the lines of disconnecting the battery , and then using a piece to connect the two wires together and then re-connect and this works.
Am I ok to do all this ? or as some people say will it mess more things up for me if i disconnect the battery?
Thanks hope someone can help
Waseem
First post here..
I am in the UK...
Waseem
