Old January 7th, 2019, 20:15   #1
redscare
TDI(s): 99.5 Golf
Fuel Economy: 45 mpg.
Default Uro brand aftermarket valve cover
Bought this valve cover from ecs tuning.
$75 verse $199 for the oem one.
https://www.ecstuning.com/b-uro-part...38103469e~uro/
I couldn't find any reviews positive or negative, so I guess I can be the guinea pig.
Looks like a quality part. Gasket is not bonded to the cover like oem, so maybe its replaceable at some point.
I'm going to install it with ultra blue on the cover to rubber gasket side to help keep the two attached.
I have 380k on my alh and have run liqui moly and total quartz.
I post an update in a few weeks.
redscare is offline   Reply With Quote
Old January 7th, 2019, 20:22   #2
Nero Morg
Subscribed, I don't want to pay that much to fix my seeping cover too.
2003 Jetta Wagon silver- DLC520 VNT15 11MM pump 5 speed
ESP retrofit, MFSW retrofit
Malone Stage 2 w/ South Bend stage 3 endurance
Soon to have freakwithracket's HID setup
Nero Morg is offline   Reply With Quote
Old January 8th, 2019, 00:43   #3
Rrusse11
Subscribed too! My guru was complaining about valve covers,
I don't need one yet, but that's a great price drop.
Cheers!
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr Brks:
Rrusse11 is offline   Reply With Quote
Old January 8th, 2019, 03:33   #4
Tdijarhead
I’m in, it would appear there is a lot of interest in one of these.
Tdijarhead is online now   Reply With Quote
Old January 8th, 2019, 04:56   #5
oilhammer's Avatar
Fuel Economy: fantastic
Make sure you swap the baffle over. I have had mixed results with Uro branded stuff. It almost always looks fine, but sometimes does not fit properly. Plastic dipstick tubes come to mind. They either refuse to snap into the metal tube or they fit too loose, or they are too tight with the dipstick itself.
I have never used an ALH valve cover, and would be curious if it has a replaceable gasket, can you GET a gasket by itself if necessary?
www.cardocautomotive.com
Old January 10th, 2019, 06:38   #6
ktmkris
I have used some uro branded parts. For the most part it is decent on hard parts. My father has a uro brand oil pan that was very nice quality. I have not had good luck with the uro electronic parts.
ktmkris is offline   Reply With Quote
Old January 10th, 2019, 07:51   #7
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
When I look at those photos I question if that unit should be used with traditional sealers (other than the 2 drops at the cam).
Originally Posted by oilhammer View Post
..............................I have never used an ALH valve cover, and would be curious if it has a replaceable gasket, can you GET a gasket by itself if necessary?
Think you meant to say Aftermarket ALH valve cover.
Old January 10th, 2019, 07:57   #8
oilhammer's Avatar
Nope. In context, I've never used a Uro brand valve cover. Context is everything.
Old January 10th, 2019, 16:40   #9
ToxicDoc
TDI(s): 2001 Jetta
The Chinese get it right sometimes - sometimes
ToxicDoc is offline   Reply With Quote
Old January 10th, 2019, 21:53   #10
[486]
TDI(s): 02 golf ALH
I just brake clean my old dried up gasket and smear RTV on it every time it is off. It's extra labor, but not $100 worth of extra work.
Old January 11th, 2019, 08:31   #11
jimbote
jimbote's Avatar
i just used one, was a little frustrating getting the gasket to stay in place but seemed high quality otherwise, next time i'll dab a little super glue to hold it ... it does come with the baffle seal and a new puck grommet
jimbote is offline   Reply With Quote
Old January 11th, 2019, 09:57   #12
oilhammer's Avatar
Good time to take apart and clean the separator mesh in the breather assembly, too. Once you remove it (four screws) you can release the clips and take it apart.
Old January 11th, 2019, 17:29   #13
jackfolstam
jackfolstam's Avatar
Fuel Economy: 42mpg
Don't use super glue on rubber, it makes it brittle and crack immediately.
jackfolstam is offline   Reply With Quote
Old January 13th, 2019, 20:45   #14
wonneber
I use to use weather strip adhesive on valve cover gaskets.
Non on the engine side, only the cover side.
wonneber is offline   Reply With Quote
Old January 14th, 2019, 22:10   #15
hcskorpio
TDI(s): ALH Bug
I have the URO one, it started seeping after 2k miles. YMMV. I'm going to bite the bullet and go with OE.
hcskorpio is offline   Reply With Quote
Experience with ALH valve cover gaskets - aftermarket on eBay? Redneck Truck VW MKIV-A4 TDIs (VE and PD) 23 January 3rd, 2018 07:49
Brand new valve cover for MK4 TDI in Portland Or., $100,P/N 038-103-469 E/F TDIntercool Private TDI Items for Sale/Wanted 0 July 24th, 2011 21:39
FS: TDI ALH Valve Cover w/oil cap - BRAND NEW! 04VDubGLI Private TDI Items for Sale/Wanted 6 August 4th, 2008 18:58
Dealer wants $547 for Valve Cover Gasket replacement force me to buy new valve cover honesttussey TDI 101 11 May 4th, 2008 11:02
Brand new engine - exhaust coming from valve cover mikeyworks VW MKIV-A4 TDIs (VE and PD) 8 April 21st, 2006 10:34
Page generated in 0.13259 seconds with 13 queries
[Output: 131.60 Kb. compressed to 110.51 Kb. by saving 21.09 Kb. (16.03%)]
