Old January 10th, 2019, 20:19   #1
NorthWoods_Tdi
Default Fuel Leak
Hi, I am just wondering if anyone has replaced fuel lines? I seem to have a small leak under the body by the passenger door. I circled the hole on the frame that fuel seems to be coming from. Not the best picture but would it make sense that the fuel lines are over that plate? Car is running fine but I imagine the leak just gets worse over time. Will the fuel lines be special order parts from a dealer or could any shop cut regular pipe and replace? Thanks for any input.
NorthWoods_Tdi is offline   Reply With Quote
Old January 10th, 2019, 21:57   #2
kdawg89
The fuel cooler is over there, it is a radiator looking thing, are you sure it didnít get hit by road debris and maybe it spraying so it looks like it is coming out of that hole?
I am not sure where the fuel lines are but if it is up inside there I donít understand why it would start leaking.
15 Golf TDI SEL DSG, Kerma TDI Tunes
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old January 11th, 2019, 06:27   #3
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
I recently had a similar problem: http://forums.tdiclub.com/showthread...highlight=leak
It was quite the nuisance to repair, but another board member helped me out tremendously by providing parts difficult or expensive to obtain. The black underbody panel hiding the actual source of the leak comes off easily with eight plastic 13mm nuts that will stay in the panel. You will need to remove it to find the source of the leak. The fuel cooler itself comes off with just two 13mm nuts. Since this is a return fuel line to the tank from the engine compartment, it is not connected to any large source of fuel that will drain out. The fuel lines are a hard plastic with push-on snap-on fittings. It is not initially obvious how exactly they work, but to get them off, you push in a hard to see black button which releases two inner 'jaws' and then you can easily pull them straight off.
My guess is that you probably hit some road debris that damaged one of the fittings. Fuel will leak out wherever in the panel it finds a low spot, so the leak is probably not exactly where you think it is. If you did damage a line or fitting, the next unfortunate thing is that they are not repairable and VW only sells replacement lines as a set. To make matters worse, being able to get replacements used from an auto salvage store are also difficult, as most of these routinely use large forklifts to move the cars around, and the forks can smash the coolers and lines.
sptsailing is offline   Reply With Quote
Old January 11th, 2019, 11:23   #4
NorthWoods_Tdi
Thanks for the input guys. Yeah, I am actually out of town so I won't get back under it for 2 weeks. I was thinking it was just an old rusty line (322000 miles), but it could be that cooler fitting like in your thread. Sounds like it will be fun but I will try to update once I get back and see if it was like you guessed. Thanks again
Fuel Leak and Oil Leak Problems charlieruu TDI 101 2 September 20th, 2016 14:32
Fuel leak at the high pressure steel fuel lines! codeblue VW MKIII-A3/B4 TDIs 8 August 18th, 2008 11:38
CEL: Large fuel leak, high ethanol content fuel dieseldorf General Automotive 10 June 16th, 2008 07:21
Fuel leak: heat dissipater / fuel cooler return lines dausone TDI 101 1 February 25th, 2008 09:19
A3 Coolant Leak (caused by fuel leak?) biopete TDI 101 1 June 21st, 2007 12:21
Page generated in 0.13057 seconds with 13 queries
[Output: 64.05 Kb. compressed to 57.58 Kb. by saving 6.47 Kb. (10.10%)]
