red golf tdi
Vendor , w/Business number
Now is the time to install one of our Custom Engine block heater kits while it's warm out! Don't wait until it's the dead of winter!
www.FrostHeater.com
www.FrostHeater.com
Great deal!red golf tdi said:Now is the time to install one of our Custom Engine block heater kits while it's warm out! Don't wait until it's the dead of winter!
www.FrostHeater.com
Clink the link within the 2001 model selection....it is described in detail there.....MeOmYo said:How do you tell if I have an early or late model 2001?
From the VIN?
x2 for everthing said above!KID A TDI said:I ordered one of these a while ago and only got around to using it recently (it's getting cold here ). It has been one of the best purchases I have ever made for my TDI.
8.3 amps is correct. Sound slike you'll need to replace your GFI in your garage circuit, they tend to be very weak in garage environments with moisture and cold.bakdoor said:Terry, just a quick question: how many amps does the Frostheater draw? It looks like (by my amateur calculations) it should be 8.33A, but I figured I'd check with you. Reason I ask is that the heater plugged in is suddenly tripping my GFCI outlet in the garage. I don't think 8.33 amps should be doing that, so I think I'm gonna call an electrician. But I wanted to ask you first.
Thanks!
