Soullancer
Hey Everybody,
After reading alot of posts, i can't figure out what the problem is with my jetta mk4 04 TDI (AXR).
Temperatures are around 0 degrees celcius right now, the car takes 15-20 minutes to ''warm'' up to 90C of coolant temp.
Problem is that once it reaches 90C, and i drive 100kmph for example, when i go off the gass and brake, the temp goes down towards 80C.
Also when i open the heater at max, temp seem to drop a little.
Need to get the engine to work to get to 90C again.
When the tempgauge says 90, upper radiator hose is warm, lower is cold.
Temp sens problem?
Temp sens problem?
