imo000
I'm entertaining the idea of selling my '05 Manual 5-speed Passat TDI with 345K kms but have no idea what it's worth since it's not a regular TDI Passat. I've converted it to a 5-speed manual wen I bought it 3 years ago and had a proper diesel transmission from Europe (FHN), all the conversion parts are VW/Audi and except for the used clutch has been trouble free ever since. Changed the clutch in February and now that issue if fixed too. The timing belt and cam shaft was done 2 years ago, the plastic coolant flange was done this winter. Glow plugs were changed under warranty shortly after the transmission swap. VW replaced almost all panels under the rust warranty. Replaced the turbo about 2 years ago. BSM delete has not been done, has a tow hitch. The car will need a set of tires, one of the upper control arms are worn (have spare to go with the care) and the check engine light comes on once in a while because of the throttle pedal but doesn't effect performance and only happens in the summer months. The right side parking brake cable is sticky, the right rear passenger door has no power and the engine leaks some oil. So in a nutshell it needs some work but I drive it every day and have been since i bought it. What would be a reasonable price to expect from this car if I would want to sell it as-is?
