Old December 1st, 2019, 05:53   #106
jmodge
Any idea how the mechanical timing became off the graph?
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old December 1st, 2019, 12:16   #107
superhl
I don't have a clue. The week before I changed quantity adjuster seals top and bottom. It ran fine other than the 4-5 rotations when starting in the morning. The timing was slightly advanced which is the way I set it. I changed the IP head seal Wednesday and timing way off. Unless losing the bolts moved the IP. They seem rather tight. Now the engine sounds louder and I have what seems like turbo lag. This morning it at least 5 rotations before engine started. It was 60 degrees outside. Did I pinch the seal. The main goal for installing the seal was to help eliminate having the engine rotate 4-6 rotations before starting. Anything I can test the vagcom to verify all is well? Also, not seeing air in the fuel line.
superhl is offline   Reply With Quote
Old December 1st, 2019, 20:19   #108
superhl
I drove a short distance from the house and it shutoff. It appears the engine has seized. Will remove the valve cover tomorrow evening. First I going to remove the serpentine belt and check the alternator. The brake lights warning appeared shortley before the engine stalled.
Old December 2nd, 2019, 20:30   #109
superhl
Lifters are hosed. Pulling the heads sometimes tomorrow to see how the pistons look. How did changing the IP head seal throw off the timing? Maybe just a consequence. The hard morning starts. The timing belt was still firm. If not fixable may purchase new 1.9 engine.
Old December 6th, 2019, 09:13   #110
superhl
I removed the valve cover and 1 valve was destroyed. The others looked fine. Timing belt was tight appeared not to have jumped... I need to remove the head. I couldn't find a valve12MM TRIPLE SQUARE CYLINDER HEAD BOLT TOOL locally - autozone, etc. I ordered one online. Should be here Monday.
Old Today, 16:48   #111
superhl
Heads and Piston-
Still can't determine why there was interference. Sending heads to Frank.
1992 Jetta TDI swap malone tune Thaines28 TDI Cars for Sale/Wanted 0 December 30th, 2015 10:51
swap TDI 1992 a 900$ Smog Quebec 0 July 6th, 2005 05:05
** FS : Jetta 1992 with 1998 TDI SWAP with mods ** GiGGer TDI Cars for Sale/Wanted 1 March 9th, 2005 22:45
Jetta 1992 avec Swap TDI 1998 a vendre GiGGer Quebec 1 March 1st, 2005 12:48
Jetta 1992 with TDI 98 complete Swap in Canada, QC GiGGer TDI Cars for Sale/Wanted 2 January 3rd, 2004 13:43
Page generated in 0.14135 seconds with 13 queries
[Output: 74.24 Kb. compressed to 65.35 Kb. by saving 8.89 Kb. (11.97%)]
