Old November 30th, 2019, 22:51   #16
tikal
Fuel Economy: 37 MPG (~ 45% city)
Update: just came back with a camping trip to Big Bend National Park. Worked well. No issues except that in a couple of situations the rack hit the ground. It is a similar situation when carrying four bikes in terms of hitting the bottom. I would say that the total weight was not more than 130 lbs (including the hitch carrier which weights around 27 lbs).
Going Westbound on I-10 I averaged 35.7 MPG driving mostly 85 MPH (speed limit is 80 MPH West of San Antonio). Coming back, going 80 to 75 MPH I averaged 38 MPG. Four passengers and the Passat is fully loaded! Not bad in my book :-)
tikal is offline   Reply With Quote
Old December 2nd, 2019, 07:23   #17
imo000
imo000's Avatar
Fuel Economy: Good enough
I would have picked up a pair of magnetic trailer lights and strap them to the back of the carrier.
imo000 is offline   Reply With Quote
Old December 2nd, 2019, 07:56   #18
PickleRick
PickleRick's Avatar
Sits about how my rack sits. It's useful. Ive thought about adding a roof rack.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old December 2nd, 2019, 17:26   #19
tikal
Thanks for the suggestion.
In general terms this solution is more optimized to me than having a higher center of gravity + noise with the roof rack. Also mileage wise I estimate I am coming ahead. I had the roof rack on my previous TDI, a 2002 Golf, and on the same route/speeds the efficiency went down more considerably with the roof rack.
Certainly there are down sides with this option too, no doubt.
Old December 3rd, 2019, 05:38   #20
Rxfire
Rxfire's Avatar
Fuel Economy: 41-44 at 75 mph w/ no a/c
Too bad that engineers cannot "cantilever" the hitch connections, so the leverage point is behind the front seats, so the leverage would "lift" the car in the middle.
Then a heavier "Swing Away" cargo carrier could be attached. I bought a used "Swing Away" for $50 (could not resist a $700 item for $50), but it has a 2 inch insert, so I had to used my adapter, which extended it rearward a bit. It works OK, but sits too low for the VW wagon, but works well on other vehicles, and is nice at the beach, as you can swing it out of the way to access the hatch/trunk.
ROLA Swing Away (there are other brands, too):
https://www.amazon.com/ROLA-59109-Ad...5376666&sr=8-1
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old December 4th, 2019, 10:22   #21
imo000
imo000's Avatar
I was talking about the the tail lights being completely blocked by the luggage box.
Old December 4th, 2019, 11:31   #22
PickleRick
PickleRick's Avatar
I want a roof rack so on road trips i dont need to drive my excursion. Between a roof rack, hitch rack and trunk i don't care if i only get 30 mph. Its double my powerstroke.
FS: OH: Charcoal cargo cover for B5/5.5 Passat wagon RexNICO Private TDI Items for Sale/Wanted 2 December 23rd, 2016 16:48
WTB: Mk4 Golf trailer hitch and or cargo carrier / cargo platform - Chicago IL eerie Private TDI Items for Sale/Wanted 4 February 26th, 2014 14:34
Class III hitch? Motorcycle cargo carrier. jaycoll2000 VW MKIV-A4 TDIs (VE and PD) 3 May 25th, 2011 07:53
Passat B5.5 Wagon Trailer Hitch cliffordkin Private TDI Items for Sale/Wanted 0 August 17th, 2010 08:17
Need advice on using Cargo Carrier w/ Hidden Hitch TDI_Cubed Upgrades (non TDI Engine related) 0 June 13th, 2007 08:29
Page generated in 0.15104 seconds with 13 queries
[Output: 83.95 Kb. compressed to 73.29 Kb. by saving 10.66 Kb. (12.70%)]
