Link doesn’t work?Will these do it?
Recently added to my kit.
I have seen those but there isn’t much to grab onto with those clips. There is no tabs?Try "Cable-operated Hose Clamp Pliers" or just Hose Clamp Pliers.
It looks like to me in order to get this pipe off the car then I need to take of that odd clamp. The picture isnt the actual picture it was only to reference the clamp. The pipe i'm talking about is compressor outlet pipe on a BRM.From the picture I think that’s one of the snap in boost hoses. As far as I know you can’t replace just the clamp there.
See above.From what I could see that pipe is an assembly.
If you get the clamp off what then? Either the hose itself is split or the o ring needs replaced or the nubs are worn down and not keeping a good seal. Also the alternative that the hose is fine and your problem is elsewhere.
