I can’t believe it.
No matter all the great, responsive communication back and forth with VW Customer CARE thus far, I received a call from my service advisor today stating the car is ready, that all they did was a road force balancing of the wheels and that the TSB's I sent - discussing optimal tire/wheel placement - don't apply to my model year. I then receive the VW Customer CARE e-mail below.
“I hope this email finds you well, and thank you for working with Tasha while I was out of the office.
I spoke to Paul, the Service Manager at Sunrise Volkswagen, and he advised me that they performed a road force balance on your Passat. He stated that this was successfully completed, and that your vehicle is ready to be picked up.
Paul is also stating that there will always be a slight pull to the right with all vehicles, which is due to how the roads are designed, to have a slight crest, as we have previously discussed. Paul is stating that at this point, the vehicle is operating as designed, and there are no further repairs that can be completed on your vehicle at this time.
Please let me know if you have any additional questions or concerns.”
WHAT THE ****!!! WHAT THE **** WHAT THE ****
I just wrote VW the following:
"WITH ALL DUE RESPECT, with the productive, responsive communications we’ve had to date, WHAT IS GOING ON HERE!?
Road Crown IS NOT the problem, as discussed. Paul can state WHATEVER he wants, but he’s wrong and the reason why I needed to reach out to you in the first place. You were going to speak with a regional technician. What came of that? At this time, appropriate work is not being followed through on and I now need to be put in contact with and speak with the regional technician.
I DON’T COMPREHEND how I have this problem, learn this has been an ongoing problem for many years, there are TSB’s on the precise matter, I offer you many possible ways to fix my car and all I get is a call from my service advisor, who I follow up with, who states all that was done to my car was a road force balance of my wheels and tires, in response to which I state “THAT ALONE WILL NOT FIX MY CAR” and his response is “I understand, but this is out of my hands”.
What happened to corrected/revised alignment figures? What happened to redoing the alignment becuase values simply being ‘in-spec’ aren’t sufficient and same can be fine-tuned and still be ‘in-spec’? What happened with employing ‘selective tire placement to improve vehicle drift/pull’ and ‘use of the Hunter GSP9700 Balance with StraightTrak or John Bean RFV200 with Opti-line to determine the best tire placement to improve vehicle drift/pull’, as detailed in the TSB’s? What happened with all that I wrote in my August 30, 2017, 12:08 AM e-mail to you, stating the sub frame needs adjustment, which I’ll repeat at the bottom of this message? After all we’ve discussed, the call from the dealer and your message to me below is INCOMPREHENSIBLE.
AGAIN, WHAT IS GOING ON HERE!? All of my communications back and forth with you, my feeling confident in the matter being worked on, and all you leave me with a e-mail repeating what Paul states coupled with work that was done (which work in and of itself cannot resolve my matter), and we’re now back at square one. Furthermore, the laughable message from Paul stating ‘there will always be a slight pull to the right with all vehicles’. PLEASE. I WAS NOT BORN YESTERDAY AND THIS ISN’T MY FIRST VW, that last of which DID NOT PULL, otherwise, I suppose, you would’ve heard of it!
When driving on a flat road and holding the steering wheel straight the car pulls to the right. NO CAR SHOULD DO THIS, MUCH LESS ONE WITH 150 miles.
ALSO, what happened with the holograms in the paint on my trunk lid and c-pillar which the dealer created after fixing the scratches the car was delivered with. The dealer made the holograms slightly better but they were still there last time I saw the car. WHAT WAS DONE WITH THIS?
I do not plan to pick up my car until I hear back from you and that additional work has been done to rectify this problem, to which end I need to speak with / meet the field technician ASAP. I am a most reasonable and respectful person, but this is NOT right. I am very upset and this can all be resolved if VW truly cares to see to it."
Below is what I wrote VW earlier today; not sure what else to write directing them on how to fix this problem:
"Please note another owner posted the below in response to my post on a message board.
Please share with all parties in an effort to fix my car. Thank you.
Before I got this fixed, the dealer told me that my Passat was up to standards and that they could not fix it, telling me the lane changing was due to road crown!
So, go to a good competent alignment shop. Have both front and rear toe set to zero. If the castor and camber right and left are not very close, your subframe is misaligned. If the shop is not familiar with this procedure to loosen subframe bolts and retorque in proper order, stop and find a shop who knows how to align correctly.
On my 2013 Passat, after the zero tow setting, both caster and camber were within 1 minute of a degree right to left. On my 2016 Passat, the right side castor and camber were way out. After the subframe was realigned, the castor and camber both sides were within 2 minutes of a degree.
You can set rear camber from 1/2 to 1 degree negative. Most dealers only use tenths of a degree not seconds of arc. Minutes of arc is six times more finite than tenths. Subframe misalignment occurs on transporters from improper tiedown.
As to alignment, most techs want to set or see readings in middle of green which is not usually the ideal setting. Now, with it set to settings mentioned, I can go a mile on turnpike without changing lanes. I’ve found that the electromechanical steering has the capability to correct for any other exceptional road crown.
P.S.: I had my car aligned at the dealer three times before I gave up and took it to an independent shop. The dealer may have the capability to do it right, but when your car is repeatedly given to the same tech who doesn't care, at some point you cut your losses. That said, there are competent dealerships and techs that can, and should, perform the work detailed here, and if you use the settings I posted, you will find that your car a totally different car and a pleasure to drive.
Last, note that tire PSI is critical on our cars, as if too high, the car will "tramline". I keep mine around 38 PSI."
I'M PISSED. I SHOULD NOT HAVE TO BRING MY CAR TO ANOTHER SHOP. VW SHOULD FIX THIS.
Can someone please, please share particular VW of America contacts with me who can get down to the bottom of this all and make it right?
