maniaq
hi guys, i've started my conversion 2 wweks ago, this is only the beginning, here in canada it's very cold so i this wwek end i'm trying to figure out what should i do with harness and ecu. maybe some of you can help me to take the better option.
option 1: take the bhw ecu 038906016r (edc16u31)and get the immo delete, and the other module (abs,cluster etc) recode, and the manual software recode,
option 2: here i have a dec15+ecu, p/n 038906019gs coming from b5 passat 1,9 tdi with the harness. so take this ecu immo delete and once again got the other module recode, i'm not sure but i think edc15+ have CAN. and tune to get the correct fuel map for 2.0 engine.
option 3: a have a bew ecu p/n 038906016h (edc16u31) once again immo delete, and run the bhw engine harness. get a tuner to get the 2.0 fuel map, switch the vgt from electronic to vacuum. ( i think this way will cost me more $ of tuning).
i google it many time and i see a lot of contradictory informations. i want to go with the cheaper way, i think it's the first one. i know the car will run without the manual software.
for option 2 i'm not sure for the CAN compability.
all your input will be appreciated.
thanks to all of you.
