annieneff
- Joined
- Jan 13, 2011
- Location
- Seattle
- TDI
- 1983.5 Westfalia tdi (afn), with flipped 5 speed V6 (dvz) transmission
Hello. Would someone measure how much space there is between the input shaft and the outer edge of the bellhousing for me. Just lay a flat bar across the bell and measure from the top of the input shaft to the flat bar. Within 1/32 is appreciated, but 1/16 will do if that's all you got .
Thanks!
Andrew
Ps. Can be a vanagon transmission or a 2000's era v6 or 1.8t Passat trans. Thanks again!
Thanks!
Andrew
