Cleared another hurdle that I have been dreading. I have a working gas pedal.
Obviously the TDI is drive by wire and the audi is cable throttle. Turns out, throttle pedal placement is very important and precise. The pedal needs to sit at the right level to be even with the brake when the brake is applied for proper left foot braking and blip downshift action. Several of my first revisions of using the mk3 pot and the audi pedal proved that is just didn't feel right. Fine for a truck maybe, but i drive hard fast and sideways on the most challenging road in the state every day. It has to be right.
The mk3 has this cable operated throttle potentiometer that will not fit under the audi dash and give any kind of reasonable throttle action. I noticed my mk4 has a much better and more compact pedal and apparently they have the same outputs and same number of pins.
mk3 on left, mk4 on right.
Problem is, the mk4 pedal doesn't really fit right either, so I ended up with a strange hybrid of the original audi lower pedal bonded to the mk4 potentiometer with a custom bracket to mount to the brake booster studs. The result is very good. I carefully measured the stock pedal placement, and this is right on the money.
Out comes the same old 3/16" winch plate for some more cannibalization
pedal side mount built
mk3 connector ready for de-pinning. It was pretty awesome that I was able to just put these pins in the mk4 plug and it all worked perfectly with no codes or anything.
bracket done
Its pretty uggo, but it works great, and you can only see the pedal with the dash in.
