so all done up and running once i figure out how to upload images i will
most of it was plug and play had issues with starting due to immobiliser but after changing ecu cluster barrel it was a case of leaving the ignition on for half hour to reset its self took me hours to figure this out hopefully helps some one
clutch pipe from master is different few brackets needed for inter-cooler and boost solenoids
throttle pedal was swapped over
lift pump in the tank needs changing
brakes hubs and driveshafts are also needed
engine mounts need to be swapped
Any one thinking of taking this task on i recommended it the gains are well worth it.
any one doing it need any help or advice pm me im happy to help
time to bleed the brakes wish me luck
