Hi, I am having spongy pedal problems with my Mk 4 (2000 GT TDI AJM engine code). It’s taken a while for me to realise but I am now thinking the problem goes back about 6 months.
I felt my brakes weren’t as good as they should have been, I didn’t think the discs and pads were that bad but told myself I was being a cheap-skate and decided to do them. So all new genuine VW discs and pads later and a fluid change, I am happy again but not for long, so I decide to bleed them again only this time I manage to run the reservoir dry and have to do a full Vag-com ABS bleed which I am not sure about as the commands from my 20IE system are a bit misleading but with the help of Ross-tech and information on forums I manage to get the hang of it and I am fairly sure I am doing it right now and have the correct sequence which was also an issue.
So to date I have done the following; I have completely changed my fluid for Dot 5.1 which exceeds VW recommended specs. I have gone through the bleed sequence in the Haynes manual, both the pre-bleed (for cars where the fluid has been run dry) and the normal bleed sequence, I have done the Vag-com ABS bleed on 3 occasions although I could only guarantee getting it right last time and the usual sequential bleeding, usually using a pressure bleeder (Gunsons easy bleed).
This takes me up to about four weeks ago when I knew the brakes were getting worse and on the advice of my MOT tester I did a gravity bleed which I had never heard of before (but did read something on here from one of the gurus), which didn’t actually help much so I followed it with a sequence bleed and the pedal was better for about two weeks. By this time I had been asking some questions on forums and someone gave me the Elsawin procedure for brake bleeding, which is similar to Bentley, (which I have) but includes the use of (VW specialist tool) a 'brake pedal actuator'. I am still unsure if I did this correctly, Wallace specialist tool (a piece of wood and a hammer, wedged between the seat and pedal but how much to depress?) to depress the pedal, then I bled the 2 master cylinder bleed screws (as by this stage I am suspecting a problem there) a sequential bleed as follows; Right rear, Left rear, Right front, Left front, Clutch. Left I take to be o/s/f and beating in mind my car os Right hand drive so master cylinder on the opposite side to US cars.
So the pedal is better again but nothing to write home about and I may be paranoid by now but after 3-4 days I think it is softening again
So if anyone has any ideas what might be going on I would be very grateful, you guys have been very good to me in the past and I seem to have exhausted the knowledge on the other site (better not say any names but no-ones talking to me now anyway) and I am pretty well out of my depth. Any ideas appreciated, Wallace.
