hello group, first off thank you all for the great insight this forum has. probably one of the best i have been apart of, so thank you for everyone contributions.
here is my next issue, 2013 Q7 TDI, i have a coolant leak, took it to the stealer and they have covered my rear main seal, but not my coolant leak. they say it is a a "bypass" valve under the intake and cant really show me, which is fine. my question would this be covered under the TDI extended warranty? the only bypass valve i see (diagram on the internet) is the valve that connects to the EGER cooler, wouldnt that fall under the warranty? or is this another valve that i am not seeing in the diagram ( which might not be the correct one, its the internet)
thanks for any insight you might have. thanks
Kristian
Kristian
