Old July 12th, 2019, 00:18   #16
duke21
TDI(s): 2.0 TDI BMN
Fuel Economy: 7.0L/100km
What was problem with 4b map?
duke21 is offline   Reply With Quote
Old July 12th, 2019, 02:09   #17
Jasengine
Jasengine's Avatar
Fuel Economy: 54mpg average
When first installed is threw an error code:
18000 - Altitude Sensor / Boost Pressure Sensor
P1592 - 007 - Implausible Correlation
Freeze Frame:
Fault Status: 01010010
Fault Priority: 1
Fault Frequency: 3
Reset counter: 78
Mileage: 268694 km
This was sorted in the next map, but would stay in limp mode, but no warning lamps.
I should explain a bit better about the strange behaviour on the other tune I had. First I think the throttle peddle calibration has been made more sensitive. DSG will change up very soon in normal driving, more so than with the standard vw setup.
If I roll into the throttle, the boost will climb quickly but at the same time the engine will sound laboured and heavey smoke, boost will keep climbing to over 32psi, so I come off the throttle slightly and the boost will recover to a normal 26psi and the engine sounds as though it has cleared it's throat and full throttle can be applied all the way the the red line at ~26 psi. I can keep the power down through all the gears after the initial strangness. It seems like pulling from low revs upsets the initial fueling.
This is why I wanted a remap to sort all this out, but it now seems the turbo is sh!te and the siemens ecu is a pain to program!
Jasengine is offline   Reply With Quote
Old July 12th, 2019, 05:09   #18
duke21
TDI(s): 2.0 TDI BMN
First, error is because that tuner didnt made proper 4b map sensor linearisation. Second can be because file from ECU with and without dsg has many diferent maps. So may be that tuner had file from manual. I know because i made file for one friend who has a3 dsg ppd and first he said car acts weird. After i get proper file with dsg, car is good.
Old July 13th, 2019, 00:12   #19
Jasengine
Jasengine's Avatar
I thought it was something to do with the DSG !
Old July 14th, 2019, 05:45   #20
duke21
TDI(s): 2.0 TDI BMN
DSG is not problem for sure. ECU map is different for engine with DSG.
BMR PD170 Siemens PPD 1.2 tuning kolkmank TDI Power Enhancements 0 July 28th, 2015 01:10
Rough / Wobble when starting some of the time ? 2.0TDi 140 2007 aircanman TDI 101 1 October 25th, 2012 11:56
Turbo upgrade 2.0tdi 140 BKD Edc16u1 TDI Power Enhancements 2 December 21st, 2010 15:48
2005 VW Touran 2.0TDI (140 Hp) Rune J Other VW Group TD(I)s 1 March 16th, 2010 01:18
2.0TDI 140 Pre-Map Essentials? Torque TDI Power Enhancements 11 December 20th, 2008 14:06
Page generated in 0.14545 seconds with 13 queries
[Output: 70.59 Kb. compressed to 62.83 Kb. by saving 7.76 Kb. (11.00%)]
