Old July 10th, 2019, 09:30   #466
wally_world_jb
Looks great @ZygoteBros ! -- and visually similar to my results as well. I look forward to hearing updates down the road to see how it's working out, and I'll do the same!
wally_world_jb is offline   Reply With Quote
Old July 11th, 2019, 23:03   #467
Zygote Bros
TDI(s): 2014 JSW TDI
Thanks! It's hard to tell from the pictures, but the car was raised evenly front and rear. Perhaps a 1/4" more in the rear. Does not have as much rake front to rear compared with the Jetta Towing springs.
Zygote Bros is offline   Reply With Quote
Old July 14th, 2019, 17:41   #468
D-Cup
Wondering if anyone has run BF Goodrich AT-KO2 in size 215/65-16 on their lifted Sportwagen or Jetta?
I just finished a camping road trip across TX, NM, & AZ in my “new” 2012 JSW and employed my Panzer Plate a little more than I wanted. So I’m wondering if these would actually fit?
I mounted 225/50-18 on my 2010 Jetta which required spacers for the rear tire as to clear the wheel-well liner - wondering if spacers would be required to fit the BFG-ATs.
D-Cup is offline   Reply With Quote
Old July 25th, 2019, 09:17   #469
Zygote Bros
Just got back from a 1500+ mile trip. Here's the verdict:
1. Car sits perfectly for me. Raised pretty evenly all around, perhaps slightly more in the rear, but not like the Jetta towing springs.
2. Still think the rear needs stiffer rear struts. The back end wallows a bit. May consider either Koni Special Active for a Tiguan or Bilstein HD for a Jetta. Koni Special Active for the front seems to be pretty good.
3. Tires are perfect! 225x50x17 Continentals on OEM 17x7 Vision V wheels. Seems to be a pretty small effect on gas mileage over the stock setup, I averaged a "corrected" 35-38 mpg on the trip so I was pleasantly surprised.
4. Car needs an upgraded rear sway bar. Too much understeer.
That's my story, here's a pic!
Old July 25th, 2019, 16:51   #470
AllieJetta
Firstly, please please resize your photo, it's way too big and causes the formatting all out for the page.
Second, whats your measured height from road to bottom lips of fenders F / R? I just installed the Tiguan front springs and Euro Tow Springs rear with 225/50R17 tires on my car as well, with the Koni shocks front and rear and it seems to sit differently from yours.
AllieJetta is offline   Reply With Quote
Old July 25th, 2019, 22:32   #471
Zygote Bros
Where on the bottom lips of the fenders do you want me to measure? At the rocker panel? I did measure previously at the top of the fender arch (see my post on 7/9/19, before I installed the larger tires/wheels).
I have Tiguan rear springs, part number 3C0511115AG (see post on 5/28/19). This spring sits at least a 1/2 inch or so lower than the towing springs.
Old July 29th, 2019, 11:21   #472
AllieJetta
Zygote - So your final measurements to the top of the fender lip was approx 27.75 FR / 28 RR? Interesting.
Wally World - Looking at your final measurements you're sitting at approximately the same? Seems unusual since you're both using different springs.
Obviously tires play a large part in this measurement, but I just installed the Tiguan fronts and Towing rear with the Koni Actives, and I am sitting at around 29" overall, with 205/55/17 Tires. I found the ride better now than with stock struts and springs. I'll be installing 205/65/16 snow tires for the winter as well.
Old July 29th, 2019, 14:51   #473
Zygote Bros
Just went to the garage to measure again. The previous measurements were with the stock tires. With the 225x50x17 tires, the measurements are now 28" and 28 1/4" with a nearly full tank of fuel.
The towing springs I had on the previous wagen were a 1/2" higher in the rear. The rake was noticeably different. I had Koni Yellows on that car (shouldn't make a difference, though).
Based on the Suplex specs I had listed for the various Tiguan springs, the "AG" springs did exactly what I expected compared to the towing springs. You really need to have cars side by side to compare.
Old September 8th, 2019, 17:28   #474
disastrogirl
Hi, lifted people!
I'm wondering if your lift has affected your fuel mileage.
2003 Golf TDi
Indigo 4 door 5 spd manual
disastrogirl is offline   Reply With Quote
Old September 8th, 2019, 18:08   #475
wally_world_jb
Originally Posted by disastrogirl View Post
Hi, lifted people!
Haven't seen any change...I'm consistently averaging 35-36 around town and 40-42 highway, depending on how loaded up I am. DSG. Riding on LLR touring tires, not super-sticky performance tires.
3 months, two road trips, and several thousand miles since lifting and I'd do it again in a heartbeat.
Sent from my LM-Q610(FGN) using Tapatalk
Old September 13th, 2019, 10:48   #476
Drclaw
Just ordered koni ASD struts. Planning on pairing with the idparts spring kit. Any good tutorial on doing the work?
Drclaw is offline   Reply With Quote
Old September 16th, 2019, 13:17   #477
Zygote Bros
Hi, lifted people!
I don't think the lift itself affects fuel mileage much, it will depend more on what wheel/tire combination you put on after the lift. I'm guessing I lost 1 mpg with my wheel/tire combination (36-37 highway currently).
Old October 1st, 2019, 09:56   #478
Drclaw
Could use a little help. I installed the koni reds and vw towing springs on the rear this past weekend. I have the hardware for the front but haven't done them yet. Install went fine, no real issues. I've been driving the car the last two days, 30 miles each day, and today I noticed a very faint speed depdnednt knock on the rear tire. Sounds like it's coming from the driver side rear. Very faint but there. I haven't gotten an alignment yet because I'm going to so the fronts this coming weekend.
Thoughts on what this could be? I pulled off the tire wheel well liners to clean and reinstalled on both sides. I did a quick visual check and didn't see anything obvious but haven't gotten under the car yet.
I should also mention that I had trouble with the strut top but when installing. The koni instructions were difficult to follow as they showed multiple configurations. My struts came with two top nuts per strut. They were both nylock nuts. I was able to get the first one started and put an Allen key in the middle of the strut then co your torquing with a ratcheting wrench. I snugged that down (didn't torque to spec) since I couldn't get a torque wrench on it, and then put the other bolt ontop and tightened that down. I'm guessing this is my issue. Does everyone use that vw strut socket tool when installing atruts? Anyone have experience with using the double nut setup?
Thanks in advance!
Old October 3rd, 2019, 21:23   #479
Zygote Bros
Thanks in advance!
I'd guess I'd be rechecking the installation of the strut mounts. Often they are the source of noise.
On another note, I replaced the Jetta Koni Special Active rear struts with Tiguan Koni SA struts. I also replaced the stock rear sway bar with a GTI rear sway bar.
The rear end is now very tight and well controlled. Reduced understeer. Not harsh. Before, the rear wallowed, not uncontrollably, but it was soft. The Jetta Konis were underdamped for the springs. Not now. Some may actually make the case it's too firm but not for me. I'll see how it reacts with a heavy load. The other plus is the rear no longer "clunks" when aggressively driven over large speed bumps. I think the Jetta rear shocks hit their extension limit.
Overall, I am very happy with the changes. IMHO Tiguan struts for the rear only is much better for a Sportwagen than Jetta struts. I can see using the Tiguan rear struts in OEM or Bilstein Comfort (B4) stiffness if one is sensitive to ride. Definitely no stiffer than the Koni Special actives. The GTI sway bar (available used for well under $100) is a no brainer, along with new bushings ($22 for the pair).
Old October 4th, 2019, 06:57   #480
Drclaw
Your using Tiguan rear springs correct? How do you think the Tiguan konis would pair with the jsw towing springs? The tow springs are even taller than the Tiguan springs, correct?
Where did you source your sway bar?
Lift for TDI Sportwagen (for oversize tires) BioDieselLover VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 January 25th, 2012 07:37
Resetting for oversize tires. Lightflyer1 OBD Scanners 6 March 24th, 2011 22:36
Do oversize tires cause problems with ABS or ESP? wesmontage VW MKIV-A4 TDIs (VE and PD) 7 August 27th, 2010 20:21
Tires for '09 Sportwagen TDI tdiatlast VW MKV-A5 Golf/Jettas 7 January 27th, 2009 04:55
Any Advantages of Oversize Tires? jaberoo Upgrades (non TDI Engine related) 8 February 19th, 2007 18:39
Page generated in 0.18233 seconds with 13 queries
[Output: 134.36 Kb. compressed to 112.92 Kb. by saving 21.43 Kb. (15.95%)]
