Old July 10th, 2019, 16:04   #1
Gli_ryan
TDI(s): B4v
Fuel Economy: 50.2 average
Default AC not accepting freon
So the ac doesn’t work for more than half a minute in my ‘96 b4v. The compressor kicks on and stays on. I can feel the air changing temps from the vents. Before the air really gets cold it warms back up. This happens when parked or at any vehicle speed. The high pressure line condensates in the engine bay and I can see the clutch still spinning on the compressor even though warm air may be coming from the vents. The parts store refill kit shows my refrigerant in the green “filled” area, however it’s on the very bottom of the range. I’ve purchased another bottle and tried to fill the system up more but even after 10 minutes of messing with it I cannot get the system to fill up any more. I know I’m filling/trying to fill it correctly, the line only goes on one fitting.
My hunch is the compressor itself is too weak to work properly and needs replacing. All fans are working and I can feel the air temp change for a short period of time.
Any thoughts or similar problems?
Gli_ryan is offline   Reply With Quote
Old July 10th, 2019, 17:42   #2
Mongler98
please do not and never do use that " cheater can" ever again. Dont trust it, dont even think for a second that the cinisium within is even good enough for a rice rocket!
There are a few things that this chould be and they are electrical.
90% of all HVAC issues are electrical, NOT charge related.
Ambient air temp switch, high pressure / low pressure switch to name a few can trigger a like symptom.
You need to check them all with a multimeter to see if they are functioning properly.
As for your charge, go get a proper set of high and low gauges from harbor freight. You need to tell us the charge at full rest when off and balanced on both sides, the High, the low, the outside air temp, the inside air temp and what pressures are like when it switches off on both high and low and how it equilizes.
only then we can give you some sort of clue as to whats the problem. Putting too much charge in WILL DESTROY your compressor AF. If liquid goes into the compressor it will destroy it very quickly so dont go adding more, and i would not even run it until you have a gauge set on it.
Old July 10th, 2019, 18:04   #3
Gli_ryan
TDI(s): B4v
If the switches are triggered will the clutch not disengage? The system continues to work and build condensation on the high pressure line.
Old July 10th, 2019, 18:24   #4
ToddA1
Fuel Economy: Dismal
Limit switches will keep the clutch from engaging. Is your rad fan running?
Autozone rents the proper gauge set.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old July 10th, 2019, 19:15   #5
Gli_ryan
TDI(s): B4v
The clutch will engage and does stay engaged after the air temp warms back up. The high pressure line continues to condensate as well.
Both fans are running and stay running. At highway speeds the air temp does not stay cool either though.
Old July 11th, 2019, 04:02   #6
oilhammer's Avatar
Fuel Economy: fantastic
The only way to properly charge it, and KNOW it is a proper charge, is with a machine after the system has been evacuated and vacuumed.
However, it sounds like you have a restriction in the system if the high side line is cool. Condenser or drier, or both. But debris generally originates in the compressor, so... you probably need much of the system replaced and what is not replaced flushed out and blown clean.
www.cardocautomotive.com
Old July 11th, 2019, 18:07   #7
ToddA1
Out of curiosity, what happens if you turn on recirculate?
-Todd
'97 B4: Stock
Rabbit build
Old July 11th, 2019, 19:46   #8
ScottSwee
Oilhammer is correct. You would need to recover pull a proper vacuum and weigh in a proper charge. If the high pressure line is condensating there is a restriction. The high pressure line should never condensate.
You should be able to feel around the lines and find where the refrigerant is changing states This would point to the area of restriction.
ScottSwee is offline   Reply With Quote
Old July 18th, 2019, 14:37   #9
jhax
I tried the canned r134 on my b4 two or so years ago. I replaced the drier. Poured in some pag oil, bought a vacuum pump from harbor freight, evacuated and refilled. No issues to this day. Since I'm poor, I returned the pump and got money back.
jhax is offline   Reply With Quote
Old July 18th, 2019, 21:41   #10
Steve Addy
TDI(s): 97 Mk3
I've done similarly, pulled the system down and let it sit for an hour then fill. I think on this car since the system was empty I put in a can of pag oil too besides what was in the replacement compressor.
I also installed new o-rings on everything. It's been working great.
Steve
the magic triangle spins in the peanut and then apex seals come out
Strava
Old July 19th, 2019, 04:26   #11
Mongler98
why the extra oil?
if your system was low on charge or empty, simply pull the compressor up and drain the oil and add new, adding too much oil WILL cause a serious loos of efficiency, its is normal to have a little oil circulating around in the lines and bits but too much will coat and pool up in the coils making less heat transfer, too much oil WILL kill the compressor. you can NOT have a liquid enter into the compressor, only gasses with some oil mist. change that to a flow of oil and your compressor is FUBAR really fast. Granted you have to add a LOT of oil as most of it will end up trapped in the filter dryer. Ever wonder why the car dryers look the way they do vs residential or commercial filter dryers? to trap extra oil that was added. If you go over the ability to hold that oil, well good by AC Compressor RIP
Old July 19th, 2019, 19:28   #12
jhax
Perfect, so add the recommended amount to the low compression side, 6oz and call it a day
Old July 19th, 2019, 19:52   #13
Steve Addy
TDI(s): 97 Mk3
Originally Posted by Mongler98 View Post
why the extra oil?
The system was dismantled and the components all replaced with R134A pieces from misc 95-97 donors.
It was all empty (sans compressor) when it was reassembled.
Steve
Strava
Old July 19th, 2019, 20:23   #14
KLXD
For future reference the book does give the amount to be added for each component replaced.
Saying no to gas for 25 years:
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
KLXD is offline   Reply With Quote
Old July 19th, 2019, 20:43   #15
Steve Addy
TDI(s): 97 Mk3
I'm sure it does, thank you. TBH I can't recall whether it was a singular pag charge or a combo charge R134A plus pag oil. Whether or not I followed the Bentley info I cannot say, that was some time ago.
I'm sure back in 2015 I took a look at it when I was doing the reassembly but that's water under the bridge and I haven't thought much about it. Could be I used the component amounts to determine how much PAG oil I added, but as I said that was some time ago and I don't remember.
Steve
Strava
Not accepting any vcds changes jason_ VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 6 April 27th, 2017 10:02
not accepting one of my documents.. Was a fordie Dieselgate - VW Group Emission Scandal 17 February 1st, 2017 07:43
Where do I add freon for the AC on 2005 Passat TDI Wagon? SoCATDI VW B5 Passat TDIs 16 April 23rd, 2014 05:26
Need AC Freon amount for 03 jetta TDI Bud44 VW MKIV-A4 TDIs (VE and PD) 2 July 8th, 2012 22:28
95 passat AC high/low freon pressure switch removal redtdi966 VW MKIII-A3/B4 TDIs 2 June 13th, 2009 13:58
Page generated in 0.16542 seconds with 13 queries
[Output: 126.13 Kb. compressed to 105.59 Kb. by saving 20.54 Kb. (16.28%)]
