ChuckV309
My wife's B5 has to crank an extended time to start. 10-20 seconds usually. It's not every time, but probably 90% of the time. It will restart immediately after shut off, but longer than 10 minutes and all bets are off. Once started, it runs perfect. There are no visible fuel leaks or raw fuel smells of any kind and all hoses are dry and in good shape.
Here is what I have done so far:
1. Removed access to pump in the tank and listened. It cycles with the key being turned on.
2. Removed supply hose from filter and observed fuel flow when key was cycled. Instantly fuel flowed for about 2 seconds and got about 1/2 cup.
All steps below had at least one drive cycle completed before the next step was performed.
3. Bypassed thermo "T" on filter. Made no difference.
4. I put a hand operated vacuum pump on the supply hose from the tank and just some fuel, no air flowed.
5. I put the vacuum pump on the return hose from the tandem pump and got mostly air.
6. I put clear hoses from the supply hose to the filter input, and from the engine return hose and the return to the tank hose (termo "T" still bypassed). When the key was turned on, fuel would flow from tank for about 2 seconds then stop. During cranking the fuel would start flowing from the tank again, but none could be seen returning to the tank. As the engine started to fire, then fuel and air could be seen in the return side. I let the car sit for a while, and then I did this a second time to make sure it wasn't due to air being introduced from putting in the clear hoses.
I am thinking the tandem pump is letting air get in the system when the engine is off.
Any ideas?
Chuck
Any ideas?
Chuck
