joelbert
- Joined
- Aug 25, 2012
- Location
- NJ
- TDI
- 2004 Jetta TDI GLS Wagon, 5 Spd, Sold-2002 Jetta Sedan auto, 2003 GLS Wagon auto project
Okay, so I find myself needing to put a new camshaft in the 2004 Jetta that I have had for a little less than a week. Some questions.
The car has 143,000 miles on it, and had the timing belt done at 102,000 miles. Do I need to remove the timing belt to do the camshaft? In a post in this thread https://forums.tdiclub.com/showthread.php?p=3288289
Tools:
In either case I assume I need the timing belt tools, are there any I can get away without? What about the camshaft pulley tools, can I get the cam shaft pulley off with a regular three arm puller? I hate accumulating specialty tools that I will probably never need again. Anyone in North NJ who could lend me a set, or sell them cheap if you have used them for your one time use?
3359
3387 tensioner tool
t10115 tensioner locking tool
t10050 crankshaft lock
t10051 camshaft holder
t10052 puller
Is there a DIY/how to thread for this? I have searched around, and done lots of reading on PD camshafts, and lubrication, and billets, and other head spinning, staying up too late after yesterday's picnic kind of stuff, but did not come across a plain and simple diy.
How tricky is this maneuver? How much more work is it to remove the timing belt completely? If I have to remove the belt I figure I would replace just the belt, but not do a full water pump, and belt tensioner replacement. Any easy way to support the engine without the nifty jig shown in Bentley?Do the timing belt. You won't need to redo that with the cam anyways. You can get the cam loose without taking all of the belt things off. You just have to take the cover off to get to the tensioner and the crank pulley. From there you can loosen the belt and get it off the cam sprocket. I was kind of thinking like you but I found out literally the hard way that you can move the belt on the cam sprocket (I put it on two teeth off).
Tools:
3359
3387 tensioner tool
t10052 puller
