Diesel Does not have a Best Before Date.
Think about your own personal situation.
Lets assume a High Mileage driver >25,000 mi /year.
Now take our older model TDIs...
The MPG generally is in the 40s to 50s.
Worst case, 40 MPG, with 25,000 mi per year . or about 2100 miles per month.
Now at 40 MPG, to drive 2100 miles gives a consumption of approx 52 gallons.
The Tank in a Jetta/Golf/Passat is approx 12 gallons, so thats 4-5 fillups per month.
The Fuel then is at a maximum , 1 week old when it is burned up in the engine.
Now Expand this cycle to your local retail establishment
A typical Tanker contains 4-5 compartments , with a tri-axle trailer holding 12,500 gallons Total.
Assuming only one tank is used for a delivery, thats 2,500 gallons per fillup at your local dealer.
Each Tank of Tandem axle dump trucks uses 60-100 gallons. Typically they fillup every day or two.
Depending on the number of trucks that pump out 100-200 gallons per fill, those 2500 gallons can be used up pretty fast.
(25 x 100 gallons or 12 x 200 gallons),
However , most retailers (owners) know how much they use each day/week.
In my town, most fuel stations get a refill every other night (it;s safer to ship petroleum fuel at night time).
Larger Stops have bigger tanks, Look at the size of the concrete pad above the tanks. This will give you an idea about the volume of fuel stored.
If a retailer were to take a refill delivery, every week of a full tanker of approx 12,500 gallons of D2 thats a
High Volume station.
If they take delivery of 1 compartment in 1 week , that's 2,500 Gallons.
This is a
Low Volume station, but still has high quality fuel, because their turnover is 2500 gallons per week.
Some retailers buy the fuel at price A and if the local price goes up they hike up the price, but will (bad Business practice) rarely sell product where they lose money on every gallon sold. ( A PRice war in the area), they probably will keep their price the same or reduce it slightly from their normal margin, but never below what they bought it at.
Check this link for the 'Rack Prices' at local terminals in Southern Ontario.
http://www.shell.ca/en/products-services/on-the-road/pricing/app-rack-pricing.html
This gives a little insight into the finicky biz of petroleum marketing.
The Retailer is sold the fuel at a 'Rack Price' at the terminal. They then have to ship and deliver it to the local retailer.
Hauler trucks generally get about $1.00 per mile (depending on Region) so it is not cheap even to deliver the stuff.
Water Condenses on the inside of the tanks due to the ambient air. Coastal and High Humidity areas are subject to more of an effect. It is controllable by keeping the tank filled.
This applys both to small tanks (12.5 gal Jetta) and 10,000 Litre Fuel Tanks.
