"Adjustable, Intermittent Wipers" on 2012 Passat TDI?
physicshogon
Virginia
2012 Passat
Hi guys
I'm having the darndest time getting the dealer to enable the "rain sensing wipers" feather on my 2012 TDI. The reasoning they keep giving me is that if they change anything that's set at the factory then it completely voids my warranty.
Side mechanics are afraid to touch it for the same reasons. From the information that I've found online, it's a pretty simple fix...yet no one is willing to do it.
The last person I spoke with today said to look at my sticker amd make sure it's a feather that I paid for. Well I took a look at the original sticker and it says "Adjustable, Intermittent Wipers with heated nozzles". I have the 2008 Passat as well and the feature actually works so I know the vehicle is capable of it.
P.S. I have the TDI SEL Premium...so the vehicle is supposed to have EVERY available feature.
Any recommendations from you guys? If so, please send me a private message here as I don't usually go back to check the forum boards. Thanks a bunch.
MyAvocation
Hoffman Estates, IL
2017 Passat SEL TSI
"Adjustable intermittent wipers" merely means more than one intermittent setting -- available on most every vehicle.
Contact a local VCDS owner for help, provide them with the DIY and agree they are not responsible for unforeseen issues. Several have successfully performed this and the rain sensing window/sunroof close mod, so I don't see what the concern is.
JSWTDI09
Las Vegas, Nevada
Hi guys
Rain Sensing wipers require the rain sensing rear view mirror. I do not know if your Passat comes with that or not. If not, you must upgrade to this sensor before you can enable the rain sensing wipers. Look at your rear view mirror mount and see if it looks like this. http://furmanka.blogspot.com/2008/08/mk5-czujnik-deszczuwiata-i-lusterko.html
Have Fun!
Don
P.S. Cross posting (asking the same thing in multiple forums) is against the rules here. Find the right forum and ask your question once, and you not get hassled for it. Welcome
