TomB
So I went to edmunds.com and did a comparison list of the features/specs between my 2005's and the new 2012.
One thing I noted was the auto up and auto down feature was not listed on the specs. This was the feature where using the key and holding it in the lock position put up or holding it in the unlock position lowered all the windows.
I thought VW had skimped on this. But they did NOT!
It is there you only need to touch the indented surface on the door handle with your index finger without grasping the handle. As well you can just hold the driver side window button up or down and it does the same.
On a bad note, you can no longer disable the ESP with the button. This is sad since on ice and snow getting started up a hill is IMPOSSIBLE with the ESP, it kills all the power while trying to get started and just never gets you going. In this case you need to be able to override the dang thing and just spin the wheels till you get some moment going. I see using the Jeep in my future winters more than the 2012 Passat.
