CharlieT
I swapped a BEW into my Audi TT, and I currently still have the gas lift pump running diesel, feeding the fuel filter and tandem pump. This is for a number of reasons related to AWD tank setup (twin tank ports) and the whole level gauge setup. I do have a PD lift pump on the shelf, but am reluctant to go through the pain of swapping it in and trying to make it work (only get fuel from half the tank, gauge works backwards, etc)
The gas lift pump seems to run fine (at least for a few weeks thus far !). It outputs ~ 4.5 l/min at no load (same as PD), and dead heads at around 70 psi.
When the engine is running it seems to hold about 50psi at idle, and slightly less under load.
My questions :
1. Has anyone else done this ? and achieved decent pump life ? I don't think I am loading it any differently to a gas motor with a 3 or 4 bar fuel regulator ?
2. What is the standard diesel fuel filter pressure rated to ?? I am guessing 70 psi is lot, but it seems to be ok for now ?!
Thanks !
My questions :
Thanks !
