nic_a_bod
I removed the EGR to take a look see if things needed to be cleaned. It's not bad - maybe 2 or 3 mm thick. Seeing it's a pita to remove the intake for a cleaning otherwise I would just do it and be done with it. Do I have to clean it now since I pulled the EGR off and have disturbed some of the build up around the joints or can I just put it back together and not worry about chunks getting sucked in?
