puntmeister
Anyone have any sure-fire method of getting the outer CV joint off the axle?
I am trying to replace the outer CV boot.
I've tapped and tapped (pounded) the inner-race to try and get it off the axle - but it hasn't even budged.
I've found some methods via searches, but they all apply to the axles/cv joints that use a bolt instead of a nut (they drive the bolt all the way through, and basically press the joint out.
No such luck on a 2004.
