rt_hawk
I took off my stock 01m trans cooler and replaced it with a tube and fin style air to oil cooler with a magnefine filter in line. Work great, trans temps are way better. Anyway, I used a hose splice that came with the sonnax kit to tie the coolant lines together. Could I put a coolant heater in that spot instead? I don't know how the coolant flows through there so I figured I would ask and see if anyone else had done this. If not, would a heater in that spot provide enough flow to be worthwhile? Or would it cause damage from not having enough flow?
Thanks in advance, Sean.
